This may be a stretch but my underhood light has never had the toggle switch it’s broken off at the base so I can’t turn the light on/off. The nut is still there though. Anyone ever replace just the switch? If so what did you use. Showing a picture of the part I am talking about.
https://www.classiczcars.com/topic/62781-under-hood-light/
The switch is but a commonly available SPST toggle switch, easily replaceable unless you want to match the Nissan white plastic switch throw lever.
This one is available form Amazon  :   about $4      Any autoparts store should have one.
  • Thanks 1
https://www.classiczcars.com/topic/62781-under-hood-light/#findComment-583258
I have a stash of the broken white plastic switches for these engine ights.  I picked up a metal one at Frye's similar to the one you have shown and used that instead.  I did take a little white paint and painted the lever part white just so it looks a bit like the original.
https://www.classiczcars.com/topic/62781-under-hood-light/#findComment-583275
44 minutes ago, ryanotown22 said:
Next I need to find a plastic light lens cover
Currently out of stock, but you can make contact to see when the lens will be available again if you haven't already checked.
https://www.240zrubberparts.com/apps/webstore/products/show/4519997
Dennis
https://www.classiczcars.com/topic/62781-under-hood-light/#findComment-583281
  • Who's Online   0 Members, 0 Anonymous, 1,142 Guests (See full list)
