Robert Bohl Posted September 6, 2019 Share #1 Posted September 6, 2019 The Temp/Oil gauge for my 1971 240Z has become wonky. I've cleaned the (yellow) wire's bullet connector to the water temp sender. However, in the same loom, there was a black wire with an unused female spade connector. Does someone know the purpose of this connector and what it should be attached to? Have I broken a circuit to...something? Link to comment https://www.classiczcars.com/topic/62800-unused-connector-on-water-temp-sender-wire-loom/ Share on other sites More sharing options...
jfa.series1 Posted September 6, 2019 Share #2 Posted September 6, 2019 The spade connects to a condenser on the back side of the distributor. 1 Link to comment https://www.classiczcars.com/topic/62800-unused-connector-on-water-temp-sender-wire-loom/#findComment-583431 Share on other sites More sharing options...
Robert Bohl Posted September 7, 2019 Author Share #3 Posted September 7, 2019 Jim, thanks! Nice looking 240Z BTW. 1 Link to comment https://www.classiczcars.com/topic/62800-unused-connector-on-water-temp-sender-wire-loom/#findComment-583459 Share on other sites More sharing options...
