Hi everyone,
I'm nearly done with my front suspension. I was able to replace the tie rod ends today.
I completely forgot to take photos before I uninstalled everything and I'm stumped. Can you guys please let me know if I have the orientation for the ball joint and tie rod end correct?
Thank you guys!
https://www.classiczcars.com/topic/62815-front-suspension-issues/
I hit a snag today. The rear strut upper spacers disintegrated when I pulled them out. The stores online don't carry them anymore except for one store but they are out of stock for a month.
Can I put the rear suspension together without using the spacer?
Do you mean the part that Nissan calls a spacer?  They compress and deform over time anyway.  You could probably use a big o-ring in its place.
http://www.carpartsmanual.com/datsun/Z-1969-1978/axle/rear-suspension/13
That is exactly that piece you linked that I'm after. Where do you think I can get a big o-ring from? It's roughly .70 inches in height.
I'd go to a hardware store.  The good ones usually have a wide selection.  You might have to stack 2 or 3 to get the height you want.  When the spacer is in place it's more like a packing material, probably to keep the metal parts from rubbing together and squeaking.
There's also online, like Grainger or McMaster Carr
https://www.grainger.com/category/hardware/o-rings-and-o-ring-kits/o-rings?redirect=o-ring&searchRedirect=o-ring&searchBar=true
41 minutes ago, Zed Head said:
I just called Nissan Parts Deal and they don’t have it in stock. Thank you though!
  • Who's Online   1 Member, 0 Anonymous, 946 Guests (See full list)
