Has anyone seen these before?
Can anyone identify this?
Since my ‘73 complete restoration is near completion I am going around my ‘70 240Z to see what is the extent of the parts that I will need before starting the restoration process.
While checking the front suspension I came across the Front Torsion Tension Strut Rod. I did not recall seeing such cap/cover on a 240Z before. Anyone has an idea if it is OEM, aftermarket or simply not beloning to this car??...
Any insights will be much appreciated.
Thank you!
https://www.classiczcars.com/topic/62816-has-anyone-seen-these-before/
5 hours ago, ZCarFever said:
@jonbill thank you!
Here's more info to add to Jonbill's answer.  Thanks to @240260280
http://atlanticz.ca/zclub/techtips/suspension/comprod/ball&socket/index.htm
Edited by siteunseen
  • Thanks 1
  • Who's Online   1 Member, 0 Anonymous, 1,502 Guests (See full list)
