I ran a long wood screw through the middle and let it press off of the inside of the passage. It cocked a bit so I punched one half in and pulled the other half out.  Rotated on the edges.  Then I grabbed it and pulled it out.
If you get the middle torn out the edges will fold in pretty easily with a punch.  The sealing surface is wide and you can use sealant on it.
7 hours ago, siteunseen said:
I ruined an f54 trying to get that rear plug out.  It's so close to #6  I drilled through the soft plug and before I could stop I'd drilled all the way into the bore.
If it makes you feel any better, that's not the first time I've heard of that.
I haven't done it (yet), but apparently it's easier than expected to do that. I don't think you are the only one.   :facepalm:
7 hours ago, Av8ferg said:
That plug is in there good. I need to have a professional remove it. I tore it up good trying.
As suggested, a hook on a slide hammer tool (or a crude substitute) would probably pop that out. Or just let the machine shop take care of it. It won't add any significant cost.
Did you get the front one out? If not, be careful drilling that one too. #1 is close behind that front plug.
No I left that one in there. After the battle with the rear one I didn’t want to risk it. I’ll ask the shop if they can get it. I’ll remind them how close the bore is to that one.
Everything is loaded up in the SUV to take to the shop tomorrow.
Here’s the task list:
1. Hot Tank block
2. Inspect and clean head
3. Inspect crank and journals
4. Hone cylinders
5. Install new core plugs (like that ZH)
6. Will inquire about shaving head.
Crankshaft journals looks beautiful to me, no signs of anything to be concerned with. Getting all this rust out of the cooling jackets and chambers will be nice and I’m sure it will help it run cooler.
I need to start ordering rebuild parts.
A question for the crowd. When I removed the pistons I had a couple rod bolts fall out on to the garage floor. Which means I lost the original orientation. They can only go in two ways. (180 deg out from each other) Each bolt has two markings on either side of the head a “12” one one side and “H” on the other. I have the correct bolt in the correct side of the rod but it may be spun 180 out. I’m assuming either way is fine but wanted to confirm. I’m only concerned because of this comment on the book.
I'm guessing the reason it's important to keep the rod bolts in the original location is that they locate the lower bearing cap against the bottom of the rod. Take a look at the rod bolts... there's a thicker section up by the head. That thicker section is a locating shaft for the caps.
Now that you mentioned it, I've got to take care of that too. I dropped two of them and I'm relatively sure I got them back in the original orientation. I know they're on the right rod and the correct side of that rod... Only thing I'm not positive about is the rotational orientation. When mine fell out, I put them back with what looked like (in crappy light) the cleaner side towards the rod, but I need to double check them now.
Have you looked at yours to see if you can use the oil staining as a guide?
Although, I'm not convinced that "interchanging rod bolts has the same effect as interchanging rods and caps". I think interchanging rods and caps is much more risky than interchanging rod bolts.
As a testament to that... You can buy and install a whole new set of rod bolts. In fact, some people even recommend that.
Of course, it would be a better idea to keep everything together and in the exact same orientation as it was originally, but I certainly don't think it's as high an impact as mixing up all the caps.
CO, that’s a fantastic idea. The pistons and rods are wrapped in cloth and individually bagged but I’m going to open them back up tomorrow and looks for the staining. The other idea I had was to put them in the direction that requires the least force to seat. That may the original orientation that goes in smoothest. I was hoping that the stamps of the bolt heads would be consistent but I don’t think that’s the case....rats.
Yeah, I don't see how rod bolts would effect clearances or roundness the way caps would. The only issue I could see would be stretch and that would be resolved if they fully reached finished torque. I also don't see how orientation would be relevant either. As CO pointed out you could replace all of them with ARP hardware and I wouldn't expect to have to big end size as long as the cap was on each mating rod.
CO, you could experiment if you have the proper measuring tools. Take a known rod with the properly located bolts. Torque it down and check the ID both ways to determine roundness. Then relocate the bolts or change the orientation and recheck. I suspect your dimension won't change as long as the torque wrench is accurate.
Regarding core plug removal: It is much easier to tap the plugs inwards. Just use a flat screwdriver and tap in one side (red line), the plug will tilt and can be pulled out easily afterwards!
Edited by german240
I tried that. That was how I did all the other ones but this one was so stubborn the screwdriver kept puncturing the plug.
Okay, so I did a little investigative work this AM to see if I could find patterns or consistencies in the rod bolt orientation. I found no smoking gun but have some observations. The staining didn’t show anything remarkable. Captain I’d like to see what you find. Since I don’t know which ones are right and which ones the bolt fell out, I can’t determine which is correct. So there is a 12 and and R on the rod bolt. I’m assuming that was stamped there for a reason.
I took one piston and rod assemblyI think is correct and placed the piston notch forward and then assessed how the bolts were oriented from both sides. It appears that on the left side (looking down) the 12 is forward (same direction as piston notch) and the right side the R is forward. CO see if you have a similar observation or anyone who has one they know is assembled right can verify that orientation. See pics below. I love a good mystery.
ba263326d6109a058c4ee2ab84851cd0.jpg&key=0cb0ee5fe4f9bf3ead850abc296a58a6acc0de36b6bbced26d1ae5444fc75a17
7b636bf65ab588b1458af0d4fa94eef7.jpg&key=c38fb2a3f945a42b0ff1b6229a9104ca5430f91b77c62e71d5433e099dd1cfbf
  • Who's Online   2 Members, 0 Anonymous, 1,512 Guests (See full list)
