I have a black two way switch on my car that was kinda screwed into the side of the console up in the fuse pannel. It sits in the middle but can be flipped either way, it doesnt stay flipped just springs back to the neutral middle position. I know it does something because the amp meter jumps when I flip it either way. And one time I flipped it and the the top left fuse (lights I think) blew out. Also what type of fuse should the top left one be, anyone have a diagram of which ones are which.
Thanks!
https://www.classiczcars.com/topic/6287-black-switch/
Only two way switch I know of that it might be would be the electric antenna switch.... don't know why it's where it is though, but if the radio isn't orginal it was probably put there when the radio was changed as they were built into the faceplate of the original radios....
What year is your car? The model makes a lot of difference in which fuse is which..
https://www.classiczcars.com/topic/6287-black-switch/#findComment-38481
  • Who's Online   0 Members, 1 Anonymous, 1,340 Guests (See full list)
