350 Short Block A/C - can it work with 260z?
depends on the line fittings. A stock 260z will have flare fittings. What kind of fittings are on the compressor you want to use. The other issue will be the location of the lines, that is prob a bigger problem. Best bet would be to just have some made up that deal with the fitting and locations you have.
