Interior Door Arm Rest Coming Loose
I have not tried this on a 240z but the arm rest in the BMW Z3's is atrocious! I took the metal bit out of the arm rest and welded a piece of bolt or screw to it. then I drilled a corresponding  hole down the arm rest into the foam. I filled it with epoxy and pushed the screw down into the epoxy to harden. Keep in mind that Z3 armrest are about $200 each not $35
You could try something similar if you could get some wire wrapped around the metal plate or drill some small holes in it. Then epoxy the wires into the foam. I work with spray foam alot at work and I don't think you will have success going that route
  • DannDZ changed the title to Interior Door Arm Rest Coming Loose
On 10/29/2019 at 5:25 PM, w3wilkes said:
Just put your car info in your Sig, and it'll always be there.
I've spent about 10 minutes looking for where I can update my sig, but no luck. Can you tell me where to make the update?
Thanks.
Thanks.
Click your name  in the upper right.  Select Account Settings.  Then click Signature from the left side and edit to your liking.  Cheers!
mike
  • Who's Online   3 Members, 0 Anonymous, 1,417 Guests (See full list)
