Horn button keeps falling from the wheel
Ok hear me out....
My horn pad was doing the same thing and it’s because the cracking plastic no longer holds snug on the wheel.  Instead of a zip tie, I used a soldering iron.
Just hold the horn pad together so that the cracks in the plastic close, then carefully draw the hot iron back and forth over the plastic melting it back together. The secret is to melt enough material for it to bond with out burning all the way through.  After doing that my horn pad fits snug and had a satisfying “click” when pressed back on to the wheel.
  • Thanks 1
I tightly zip tied mine then Gorilla Glued it. The trick for me was carfully engaging those 3 metal snap clips as you turn it into place. I don't use the horn button anymore. The middle finger works just fine out the window of a bright orange '72 car.
  • Haha 1
I made a ring from some thin sheet copper, it was about 1/4 wide and about 1/32 think sheet. Solder the ends. the ring thin slips down just around the plastic part, digging into the foam a bit,
but since its so thin (1/32) it slips in pretty easy. Just have to size the ring correctly before soldering so it grips the plastic from the outside tightly.
  • Who's Online   3 Members, 0 Anonymous, 1,141 Guests (See full list)
