Horn button keeps falling from the wheel
 I removed the foam from the outside of the cracks (enough to expose the outer side of the cracks), epoxied the cracks and also filled the holes left from the removed foam and used a hose clamp to hold the plastic ring tight while the epoxy cured. Be sure to remove any epoxy squeeze out from the inside of the ring before the epoxy cures.
  • Who's Online   2 Members, 0 Anonymous, 1,582 Guests (See full list)
