Thanks Jeff!
I got it all hooked up and it cranks over just fine. I can't wait to start it. I have to torque the drife shaft flange bolts and then put in some transmission fluid.
Once again, I appreciate your help very much.
Isaac
Originally posted by spunkysandoval
BTW,
On putting some transmission fluid, how is that done? Where do I fill the transmission from? I have a 260z transmission type F4W71B. Oh yea, its in the car installed.
thanks, Isaac
I do not know the #'s of ALL the transmitions ever made for a datsun. Therefor all I need to know is if yours is manual or automatic. If you have a manual then you will fill the trans via squeeze bottle. The fill hole is the full level,fill to the hole. If your trans is auto fill it through the fill level dipstick tube.
- Jeff
Thanks agian!
I found it, I found it. Tomorrow I will borrow some torque wrenches from school and finish torqueing everything down and try to tune my carbs to match my new cam.
Or maybe I'll just take it to get tuned somewhere that has a dyno.
Any who thanks a bunch
isaac
  • 3 weeks later...
  • Who's Online   3 Members, 0 Anonymous, 655 Guests (See full list)
