R200 conversion using Whitehead Mustache Bar
9 hours ago, Yarb said:
Thanks, What do you think about the slanted off set washers that come in the kit. I was told by Whitehead they are used for leveling. OEM doesn’t require them. Just wanted a bar to bolt on and put my rebuilt suspension back together. The other concern is once it’s installed it’s mine.
I have never used slanted washers but they are a good way to help align the nose of the diff for pinion angles, on modified cars with different engine/transmission combos sometimes you need that adjustability .
