Trouble Reattaching Speedometer Cable
  • 2 years later...
On 3/20/2020 at 6:02 PM, daty240z said:
Thank you for the suggestion. I ended up grabbing the cable at the speedo end with a pair of vice grips and pulled it out about an inch an change. It definitely needed some force. After that I realigned the cable with the speedo and felt a much more significant "drop-in" than previous attempts. Turned the car on and it worked like a charm. Thanks again, super helpful.
Does anyone know how to reinstall correctly the speedometer and tachometer in a 1972 240z without removing the dashboard? Trying to find pictures or videos on youtube but no luck yet. Anyone?
3 minutes ago, jalexquijano said:
i need more specific details and pictures to reinstall both intruments correctly without messing anything. I have short under the dash and need to trace it.
google.com but end your search phrase with classiczcars.com.
Click on images for pictures.
Good luck.
  • Agree 1
