Transmission Crossmember bushings
On 9/7/2021 at 5:10 PM, Yarb said:
If you go with Poly, Do not remove the bushing sleeve. They are designed to fit in the inner portion where it’s deteriorating. Ask me how I know!!!
How do you know?  The poly bushings don’t fit if the sleeve is left.
1 hour ago, Yarb said:
I removed the entire bushing on my 280 and the poly bushing flopped around in there. It was designed for the sleeve to stay in tact
280 is the key.  I believe the crossmembers are different between the 240, 260 & 280’s.
