Turn signals indicator points wrong way!
I had put this in the emergency forum.
I just installed a new dash in my 1972 240z and now the indicator light in the dash points the opposite direction of the lever.  The turn signals all work.  I had cleaned the contacts in the turn signal.  Brake lights work.  Flasher works.  Also, my left headlight is now real dim.  Any help is appreciated!
34 minutes ago, marks240z said:
It's a new Vintage dash.  I'll try going through the tach.  Thanks.
They're in the back of the tach.  So you won't have to go through the tach to get to the bulbs.
These doppelganger threads are getting weird....
  • Who's Online   2 Members, 0 Anonymous, 1,327 Guests (See full list)
