ahhhhhhhhhhhhhh how strange i literally just did this a couple hours ago. There is a m3 bolt near the steering wheel, and an m4 bolt at the underside of the key tumbler. I think i used some small #6 screws for the 4 other ones that go into the plastic. I did not torque them down all the way, i was scared it was going to ruin the plastic on the other side.
For the m3/m4 i had to use a washer to get it to hold to the plastic. I should have done it months ago, it looks great.
I used some zip ties to hold the wires to the steering wheel column.
it seemed to be a bit more coarse than a machine screw would be. I stand corrected, based on https://www.boltdepot.com/fastener-information/machine-screws/machine-screw-diameter.aspx
I was using a #8 screw.
overall height is 0.6"
diameter is 0.165"
length is ~0.5"
Edited by heyitsrama
On 4/19/2020 at 6:14 AM, AZDatsun said:
Wow thank you for doing this that is great information you really went above and beyond to help me out
Glad to help, just wanna keep the helpful attitude going on this forum! Lots of friendly people here ?
  • Who's Online   1 Member, 0 Anonymous, 1,493 Guests (See full list)
