9 minutes ago, wadelester said:
putting the check valve on the other side of the fuel filter allow you to retain that fuel too?
Sorry to but in but yeah i think so..
My early 240z starts when warm in a little kick from the starter but when cold i Always have to start a longer time, he Always starts but it needs to suck some gas.. i think.. on the other hand there should be enough gas in the carb bowls.. never realy investigated it but always started that way.. (Mine has no check valve )
I've removed my mechanical pump and have gone electric at the tank. When cold I apply full choke, turn on the key and let the pump run for a few seconds until I hear a slight change in the pump sound which I think is when the system is fully "charged" with fuel. Then holding gas peddle to the floor it always takes 5 to 10 seconds of cranking before it comes to life. Once it fires up I can reduce choke to almost nothing and by the time the oil pressure comes up I can eliminate the choke. When the car is warm I just bump the key and it starts right up.
On my '73 it was about the same story as my current early '71. I had the full dealer stuff on the '73 to address vapor lock so it had both electric and mechanical pump.
1 hour ago, wadelester said:
@David Downs would putting the check valve on the other side of the fuel filter allow you to retain that fuel too?  Just a thought.
I installed the check valve between the fuel filter and metal fuel rail to the SU carbs.
I'm going to add the electric fuel pump soon.
You could plumb one of these up in to the cabin.  It's funny, but I had to do a similar starting routine on my EFI engine after I removed the cold start valve.  Crank for a couple of seconds, wait for fuel to vaporize around the intake valves., then fire it up.  That was only after it had sat for a couple of weeks.
https://www.dhgate.com/product/fuel-pump-hand-primer-bulb-all-fuels-length/404919119.html#seo=WAP
  • 4 months later...
have you figured out the issue ? i’m having similar problem. if i prime the fuel system to get fuel in the filter it’ll run. once it sits the fuel drains out of the filter back to the tank and won’t start. i’ve replaced the pump twice and redid the fuel hoses and blew air threw the hard lines to ensure it’s all good. i’m thinking of dropping the tank to clean it out
I know we’ve gone off topic a little, however, permit me to add to the chorus ....
I was going to fix this issue with a non-return valve, however, as my incredible mechanic of a father in law pointed out: if the engine has been standing for a while, there is a benefit to cranking for 10-20 seconds without it firing, as it gets the oil around first. On my engine, the oil pressure starts to rise on the gauge just before it fires. So I’ve stopped worrying about it when I crank and instead enjoy the thought of all that lovely oil covering the cam and the bores before the revs arrive. ;)
If you use the original style filters, they have a simple and effective non-return built in, by having the vertical inlet pipe inside the filter housing higher than the normal height of the fuel in the filter. So it “shouldn’t” be drying out unless you live somewhere mega hot and / or have an air leak somewhere.
8e5a1fe325f5fe913a6902941e74959b.jpg&key=17019723b315874a5c61192eeedfea209dad26fa1f93effc1b3d7d20697f2467
Despite the fact that the float bowls and fuel lines have fuel in them, if there is air in the pipe work, the pumping action is just compressing the air and you’re not building sufficient fuel pressure as a result; until it’s blown out of the return line’s restrictive orifice on the fuel rail and the float bowls (depending on where the air is). I would imagine that when standing, the floats in the bowls aren’t fully closed and over time, air is very slowly sucked through them back into the fuel rails.
After stopping the car, heat soak will warm up the float bowls and the pressure from the fuel vapours will blow some fuel out of the bowls through the jets, or indeed evaporate through the jets, thus marginally reducing the volume of fuel and the floats dropping. Remember, when the engine is off, the jets are still somewhat open. The fuel then cools, the floats drop further and hey presto, you have a way for air to enter the feed lines. Notwithstanding of course that the fuel in the rails also heats, pushes through the return line, then cools and sucks air from anywhere it can.
So in short, even with a return valve you’re not totally going to fix this issue and frankly, it’s a benefit in getting the oil going after a long period of standing; replacing what gravity and heat soak took off the areas it needs to be, before the straight 6 warbles into life!
You could plumb one of these up in to the cabin.  It's funny, but I had to do a similar starting routine on my EFI engine after I removed the cold start valve.  Crank for a couple of seconds, wait for fuel to vaporize around the intake valves., then fire it up.  That was only after it had sat for a couple of weeks. https://www.dhgate.com/product/fuel-pump-hand-primer-bulb-all-fuels-length/404919119.html#seo=WAP
Finally, under pain of death don’t EVER plumb this into the cabin!! There are very good reasons why fuel lines are not routed inside the cabin. The last thing you need is to be the meat in a car-b-q with its own fuel source, or should that be sauce? Dad joke alert!!!!!
Essay over - Less of a chorus, more of a bohemian rhapsody I fear! ;)
I rebuilt an original pump and it seems to have fixed my issue. The check valves in the aftermarket pumps are junk. I would take apart one of your failed pumps and look closely at the check valves. It was obvious my check valve failed.
This was meant as a joke.  Thanks AK for clarifying.
