Hi All,
Got a fun clicking noise coming from my L24, goes up with engine revs. Just replaced a worn camshaft and rockers trying to solve it, valve lash set cold. Engine is an E31 from an earlier car. The old spark plug lead pull seems to quench it a little. Anyone recognize it?
https://www.classiczcars.com/topic/63934-e31-engine-tick/
How do the cam lobes look?  Looks like the PO used the wrong lash pads.  Maybe put a new cam in and used the old rocker arms and pads. Tthat's probably where the clicking came from, as the lobes slipped off the ends of the rocker arms.
So, yes, bad news.  Maybe not terrible though.
https://www.classiczcars.com/topic/63934-e31-engine-tick/#findComment-598464
They don't look terrible.  Get the right pads and you'll probably be fine.  Looks like the valve stem heights are uneven too so you'll probably need to do each one individually.  Tedious.  The other guys know more, that's what I see though, and it fits your ticking noises.  Several lobes are at then end of the wear pad.
https://www.thezstore.com/page/TZS/PROD/10-2041A
https://www.classiczcars.com/topic/63934-e31-engine-tick/#findComment-598468
Sounds half salvageable then. I see that there’s only .150 and .160 at Motorsport and anything above needs an aftermarket retainer. Is there sizes between this? As far as I’m aware my retainers are all OEM
https://www.classiczcars.com/topic/63934-e31-engine-tick/#findComment-598471
I once had a loud click on my '70 and it turned out to be the water pump  (I thought it was perhaps a rod bearing).  Turns out the bearings on the water pump were getting bad allowing the shaft to mis-align enough to have the impeller vanes hit the housing, causing the click.
https://www.classiczcars.com/topic/63934-e31-engine-tick/#findComment-598536
sure enough, measured my rocker guides and they’re all stock .120 size, albeit a bit worn. Rechecked the wipe and it’s way off on a couple cylinders. Most worn (thinnest) pad on the worst one still produced a bad pattern. I’ll check valve heights off the machined valve cover surface but it looks like I’ve got a trip to the machine shop to schedule?
https://www.classiczcars.com/topic/63934-e31-engine-tick/#findComment-598555
VR1 High Zinc
Put my oem rockers back in to check their pattern, still not great but it looks like there’s a slight difference between the one and ITM units.
Is this a valve stem fix? Can the OEM pads be safely reduced?
Edited by Maritimer
https://www.classiczcars.com/topic/63934-e31-engine-tick/#findComment-598572
  • Who's Online   1 Member, 0 Anonymous, 1,527 Guests (See full list)
