Yeah, that one was a real bonus! I was cleaning that connector with the 100% expectation that it wouldn't have any effect, but (roll eyes) I had to perform due diligence and clean it before I moved on to more difficult solutions. It was just the right thing to do.
Bonus!!!  Sometimes you win one!   :beer:
I guess I'll keep that new sender lock ring and sealing O-ring in a box on the shelf!  Haha!!  And buy a lottery ticket?
  • 1 month later...
Ewwwwwwww!!! That's got to be worth a quarter tank at least! Maybe a third!    LOL   Woof!
That's a perfect example of why I say... "If you have a couple moments of free time with nothing to do, clean some connectors on your old Z car."
LOL!!! Well this is how close to F it used to get, quite surprising really!
58f3eea7301d2d9eb4ce1e7e833959c9.plist
So I’m expecting serious overshoot when cleaned up ;)
I discovered that the fuel level sensor was leaking on the live terminal where there is insulating plastic, remember this photo?
9a92a4f080aba7419e1b3251c8266073.jpg&key=d72222c31ef873f1c1a9b398ed0ca43dded1c6c92346c6701aaf2684c289f2ec
To confirm it, I hung the thing from the float over night, with the “bowl” bit filled with self penetrating oil. The next day there was ample oil on the other side to prove it’s no longer air tight. I could have repaired it with fuel resistant mastics but I started to look at the cost of a new one. Utterly HORRENDOUS prices. Over £300 for the right shaped one. Then one appeared on eBay advertised for a Datsun 510 with very similar kinks etc so I took a punt at £40!
Today, this little package arrived ...
ac73b658c32039656bc8522ecd4b5481.plist&key=9444a84ac099c6dc8a7239efdbc7f5bc54399971e2545dc3f4a1a9cecc5c01e7
Now you can see the differences below:
4977172959488749d8c3f5924038d8b0.plist&key=e6524ec60439ab597b05901e64768257caf4701ad5795bff616a758c15ef4b35
7bbeb1e9a61dddadbf63b92f99165977.plist&key=971898c09be7b2e87253f92501bb132bac1b767571caa2f5bf3f46a7d1d23c20
The resistances however are virtually identical +/- 1/2 an ohm. 10.8 ohms full, 88.5 ohms empty.
I was tempted to move the rod and float from one to the other but decided that as it involved cutting the squashed end and re-calibrating, I was going to have a go at bending the new one first.
3c1d4b51cebe26d83057c5bc6bca1c89.jpg&key=98640718b08b3a54168a32493b318719a60e0f73a8e3ff2d5dded4a97c79a4b4
I straightened up the first kink on the new one, measured the length of the same king on the old one and bent it in the same place as the 260z sensor. The end result? Ignoring the parallax of the iPhone lens, it turned out utterly perfect. It even sorted out the difference in length - they are now identical in length also.
b3e80b26a1417e055902d5df13495c9a.plist
I gave it a test run in the fuel tank and fortuitously, there is plenty of room in the tank for the float to sit the opposite way round to the original. The bottom of the tank is actually deeper at that point and thanks to the PO has a raised bit where the POR treatment wasn’t fully flushed out. That will give me “reserve” when the gauge is on empty.
A total win!!
Next up, a test on the car electrics to see it “turn up to 11” on the gauge ;).
  • Like 4
Clever boy!  What a great idea, thanks for letting us know.
Thank you sir. - glad to be of service. BTW, found an even cheaper solution on eBay. A Datsun 720 or 620 sensor would have also done the trick at £28 posted!! I would bet my left testicle* that the ohms will be the same on all these sensors as the main unit is identical, just the float and bends are different.
https://www.ebay.co.uk/itm/164126554844
aa8324df9f6ed604be6af5dbd64b31ee.png&key=1f18f254647d8d80b62dcbf565220cdf59e49a06796ecf03f0002a14982d0e5bba1055411b5cb07728a7c7ff0e6bfff4.png&key=16658fa3ff68c5be53b3d987da246afe7a34706c49fa3917987e2f67fa17e6fc
(* not ever planning to have kids again, this is an easy bet! In fact, don’t do it gang!!! Dodge that bullet and live longer, happier, wealthier lives! But that sounds very similar to my S30 ownership too!! [emoji848] Maybe I should just go back to bed and stop prattling on.)
  • Haha 1
  • Who's Online   1 Member, 0 Anonymous, 1,444 Guests (See full list)
