I could tell you the way I've done 2 so far with Red-kote. Cost $50 a few years ago. Muratic acid, redkote, baking soda, 5 gallons buckets and about a month to completely cure. That could be cut down to a week if you keep it in sunlight.
Read over these instructions and see if you may want to try it. I can find my post from back then and let decide. It's easy but time sensutive and yoy have to get your "ducks" in a row. $$$ was my decider.
4 hours ago, Av8ferg said:
I was going to do it myself but I changed my mind and had it done professionally after meeting a guy who was doing it himself.and I’m glad I did. This guy put BB’s in the tank to break up the rust and could never get them all out: .
BBs sounds like asking for trouble. I was going to go with a cluster of smooth stones at the most. Not even sure if the POR15 process really needs it, but I'll see.  I think the kit comes in early this week. I'll let y'all know how it goes.
 I saw a similar method a while back that consisted of a gas tank duck taped to the opening of a concrete mixer. That fellow used spare nuts and bolts (noting the quantities) for the abrasive material.
Edited by Mark Maras
How about a heavy chain?
There are too many nooks and crannies I think for a chain. If you use nuts just make sure you count them so you know if you have left any behind.
I would find a local radiator shop to tank it and then you can coat it yourself with POR-15. The EPA has been putting the smack down on radiator shops at least that’s what the guy in Memphis told me. They’re getting harder to find.
  • Who's Online   0 Members, 0 Anonymous, 1,497 Guests (See full list)
