What do you mean by "redo"?  I like to use carpartsmanual to see if part numbers changed.  Looks like the control arms, AKA transverse links, changed in august 1973.  Not clear what the change was though.
The axles changed in the cast hubs, somewhere in 73 for the 74 model year, but it looks there were a bunch more changes along the way.  Part #1 and 2.
http://www.carpartsmanual.com/datsun/Z-1969-1978/axle/rear-suspension
@Zed Head I rebuilt the entire left side suspension, but really don’t like the way control arm fit into the assembly.  My guess is that the bushings won’t last long.  I can go with what I have, but thought I may try buying used on eBay, hence my question.
If you didn't bend anything you could always go back to stock bushings.  They seem to be available.  If you mean the casting when you say "assembly".  You''ll be back to where you started but with new rubber.
http://www.carpartsmanual.com/datsun/Z-1969-1978/axle/rear-suspension/57
https://www.nissanpartsdeal.com/parts/nissan-bushing-link~55541-e4100.html
I read on the internet that the later control arms got beefier. Thicker steel and maybe some additional gussets here and there for strength.
I don't know if the form-fit-function changed when they got beefier, but if not, even though they are different, they may still be "interchangeable".
  • Who's Online   0 Members, 0 Anonymous, 1,385 Guests (See full list)
