Any one here have the Toyota solid rotor S12+8 caliper set up on their 240Z? Do you like them?
I finished the install on mine. Going to try them out. Should be back on the ground soon.
Removed the backing plates instead of trimming. Need to finish the bleeding.
https://www.classiczcars.com/topic/64126-using-toyota-s128-calipers/
They are not bad but they tend change the balance so the front is doing most of the braking and the rear drums are hardly doing anything.  If you install the Maxima calipers on the rear with some sticky street pads it is a better balance but the nose of the car will still drive down in hard braking.
