Just my opinon, but I suspect that the "11mm" hex fittings that you have aren't 11mm. They are more likely 7/16 in flare nuts with metric threads... (7/16" = 11.11mm, the wrenches are interchangeable.)
I didn't think to check the lines that I bought, but they might be SAE-Metric hybrids as well... for me that is fine, but I agree that on a "restoration" that would not go over well.
Hmm, interesting. You certainly could be right about that. I'll try both wrenchs and see if there is any noticable difference in fit. If they "created" a hybrid fitting, I'll have to ask next time if they can "create" the right 10mm fitting. They had mentioned that most of the wait for the lines (almost a month) was for the fittings to be made. I assume they out-sourced them.
Thanks for the info. Where did you have your lines made, Walter?
Actually, I just bought bulk brake lines at the local Advance Auto Parts and am in the process of bending them by hand to fit.
Or I would be doing that, if I wasn't working 70 hour weeks to try to get a huge project finished at work... :mad:
Oh well, I guess it pays for the parts...
  • Who's Online   0 Members, 0 Anonymous, 1,451 Guests (See full list)
