'75 280Z - Starts and Runs, Shuts Off after 30-60 minutes
Just now, Zed Head said:
2nd edit, actually a post...just curious.  I wonder if people could pop their caps and see if they have rubber on there.  To CO's last post's point.  Just one of those curiosities.
TBH I didn't know there was supposed to be a gasket there either.  The gasket seems to be NLA though...
I have one on my cap. It's a black washer and if you poke at it with a screwdriver tip you can see that it's not quite as hard as the plastic cap, but it's pretty hard. Maybe 1/16 inch thick? ID is a snug fit on the threads, and the OD is about the same size as the raised boss on the valve cover?
I don't know how compliant they were when new so I don't know if it was always that hard, but I suspect it was slightly more compliant years ago. Every Z I've messed with has had one. I think you might just be not realizing it's there. It's really easy to mistake it for "part of the cap".
I'll take a pic tomorrow if someone doesn't beat me to it.
Nope.  I looked closely because I thought that there should be one.  Then I thought "what a fine piece of engineering and manufacturing".  The reality is that they didn't need one there, as shown by my leak-free cap.
I saw this image before and looked at my cap. Mine looks like one piece. I thought about poking it with a screwdriver. I need to take another looks at it. I see a little oil around the cap, and was thinking about getting a more pliable seal.
The seal on my 240Z is more obvious.
Right. It's easy to mistake it for part of the cap. Here's some pics.
Cap, as it's normally seen:
Close up of the seal in-situ. Looks like all one piece:
But in fact, it's not. Used a thin blade to get a little separation and get things started, and the seal comes off. Note the step on the seal and the recess on the cap. Speculation on my part, but I bet the earlier seals (with the different part number) didn't have that feature:
And here's a close-up of the cap with the seal removed. You can see the recessed area for the step.
9 hours ago, Bigz Zee said:
Mine looks like the last pic, with the seal remove.
Yeah, then yours probably petrified and fell off some time in the past.
And for the guys with the O-ring style built into the valve cover, I guess that's the older style. according to the documentation, they changed over to the newer style in 71.
