1 hour ago, Zed Head said:
Remove a spark plug and post a picture of it.
Well Ed I got the red one running by pulling the plugs & priming each cylinder, once it fired up I blew it out on the freeway. (carboned up from cranking it) I have never seen 6 plugs/cylinders) go bad all at once. I will try the same thing on my white Z. Thank you for staying with me on this. It filled me with anxiety & I bothered 3 of the best mechanics in central calif. over this. If You have a regular email I'll send you some pictures, my Z's ar really clean & I drive them up bumpy dirt roads in the sierras all the time. I am @kelley0352@att.net
Under what ? I don't see a paperclip anywhere. I pulled all the plugs out of my white Z , cleaned them, primed the cylinder, replaced them & still won't start but it does kick a little like it is trying to start
Edited by kelley0352@att.net
clarification
Click on choose files underneath the response box.  A new menu will open that lets you pick files from your computer or phone.  When you pick them they will be put in to your response.
Still have not found a response box. Still having the same problem with the white Z with zero miles on it that ran for 3-4 minutes then died never to restart. Pulled all the plugs, (they were carboned up also) buffed them off because they are new also, shot gas into the cylinder & cranked it over, got nothing. I shot either into my white Z & still got nothing, has 12v @ injector plug. it is 101 degrees here now so I think i am done for the day.
