some of the harvesting and transplanting operation. I pigtailed the remnants from the hot side of the can inserted one lead of the thermistor, crushed and then soldered. Removed the old filter material (copper weave I think) soaked in vinegar to remove the scale, then reassembled soldered up the other lead to the can. The OE can works much better as far as getting the fluid in and out of the can.
I am going to clean and touch up that solder on the bottom. I thought I had the lead cleaned and tinned but it looks like it could be better.
Amazing, delicate work, Dave! So... does it work?
Sent from my SM-N950U using Tapatalk
very well so far I will post up a video tomorrow demo of it working. Right now I am testing by letting is set in water for an extended period of time, monitoring the current (it seems to idle at about 30ma when submerged). One thing that is different is the fact that the donor had a rather elaborate plastic container (the before mentioned 2oz plastic container) This container was mounted on a wire just like the stock Datsun ( a stiff wire to the mount flange). I can only assume the OE Datsun was designed to operate with out said container, perhaps that has something to do with the hole size etc...
I did not notice any filter media on the plastic container, but then again I did not look at it too closely. The OE Datsun unit drained VERY quickly.
Edited by Dave WM
No offense to Dave, but is there more info here than for the ZCD thermistor?  I'm looking for that set of DIY parts that a person could put together on their own.
If he used just one bulb would he have the same problem that the ZCD sensor has?
I checked all the available information on each one of the 5 bulbs I'm running the tests on. The number imprinted on the base of the bulbs does not coincide (with two exceptions) with the number assigned to it on the company's web site or on their sales receipt. However I think I was able to match them by cross referencing information and images. Remember that I assigned numbers 1 through 6 to the bulbs related to their measured cold resistance in descending order. "Glow" is subjective and refers to the perceived intensity of illumination when the erroneous signal is triggered by the Zcar Depot thermistor. Here's the full info on each bulb:
Bulb #______Volts______Watts_____Amps_____Resistance_____Glow_____#on base______#online___
1                     14               1.12            0.08             19.8                      +               756                    9428049
2                     14.4            1.44            0.1               12.7                      ++             813                    813
3                     14.4            1.728          0.12             11.5                      ++            1445                  274020
4                     14.4            1.872          0.35             11.4                      +++          1892                 274004
5                     14                2.8              0.2                 6.3                      ++++         363                   363
6  (OEM)        12                3.4                ?                   3.8                     +++++       NA                    NA
Bulb 6 has been ruled out since it illuminates very brightly when triggered.
Bulb 5 Illuminates more softly but is still barely visible in a dark cabin. Could work as a "monitor" of the system in working order (see previous posts).
Bulb 4 illuminates softly enough when triggered that it is not visible during daylight and very hard to see in the darkened cabin. If it brightens enough once the fuel level falls beneath the thermistor, then this bulb would be a reasonable and simple solution to the problem. I'll report on that once my tank is empty.
Bulbs 3, 2 and 1 have yet to be tested but they might illuminate too dimly to be effective as a low fuel warning once triggered by the thermistor even when the tank is empty.
Edited by dmorales-bello
That's an excellent question. It seems from all our musings and experiments that the thermistor has to be appropriately matched to a specific enough bulb for the system to work properly.
more results,
yes the bulbs are GE47 (standard 6.3 volt used in most vintage electronics, series connection results in approx. same resistance as the bulb in the fuel indicator light.
late Saturday night experiment was disappointing. While the setup worked perfectly at 1st (out of water light comes on quickly 30s or so, in water light goes out within 1 second), continued testing showed that if left in the water for an extended period (in my case 45 min) the light was on. It was somewhere between 15 min and 45min when the light came on (I was not watching constantly).
while monitoring it I noticed the mA slowly going up, I incorrectly assumed it would stop at some point as it entered a steady state of water temp. Wrong. I left it at 15 min at about 60mA up from starting at 30ma. Came back at 45min and I was up to 190ma an bulbs lit.
Oddly I could not get the lights to go off even after blasting it with contact cleaner (very cold), Thinking I had destroyed the thermistor I considered an autopsy but decided to bag it for the night just in case I was missing something obvious. oh and the resistance was fixed think about 200 ohms but cant recall.
Next day everything is back to normal, hmmm, same working comes on out of water goes out in water. Thinking maybe I should test in fuel rather than water JIC it makes a diff (surface tension, cooling effect, etc...) so this time I use some fuel, works as expected, on out of gas, off in gas. left it go for at least 45 min, still off in gas, lift it up, goes on quickly, back in gas off again.
I also had this gas rigged up with a heat source to elevate the gas temp to upwards of 130f. Thinking it would not be uncommon for the gas in the tank to be  warm. No effect works fine.
Right now I am testing again with the intent to operate for hours with warm gas and see if it stays off.
I will post up the videos I on the testing later today after the long term test is complete. I think I will also try the test with just one light (the 6.3v) just to see how sensitive the choice of the bulb is (big change from 2 bulbs in series to a single bulb), after I complete the long term test that is.
Edited by Dave WM
I will be addressing this specifically. IF my long term test are successful with the current testing using the 2 GE47 6.3v series bulbs, I will remove on bulb from the series (that's a drastic change) and see how the system works. I will be posting an interim video in a few mins to set the stage.
Edited by Dave WM
not really. but I will test the system to see just how sensitive the setup is. IF it turns out that a wide range of bulbs works then perhaps we can assume that maybe its not as critical as it may seem. in which case a simple resistance/physical size may be enough. I may end up just buying the specific thermisor referenced by some of the motorcycle guys to test as well. that will give us an exact part number to use. At this point I just want to see if I can replicate the prob Dr. Dave is having.
Edited by Dave WM
What I am also wondering is the thermistors use in a circuit. Was the later model stuff (like the 91 Toyota) really just the same deal a simple bulb/battery/thermistor setup like the Datsun OR was it more complicated perhaps a latching relay or some transistor bias adjustment or such... anyway testing will continue.
I kinda like the idea of a latching relay, trigged on just like the bulb, but once on break the current flow to the thermistor, leave the light on until the ign key is turned off to reset the latch. This take the thermistor out of the high heat for an extended time as well after the latch is set.
for more reliable that the relay perhaps and SCR could be triggered by the thermistor. I like it since once triggered like the latching relay, it would stay on until the ign key was turned off.
Edited by Dave WM
