Okay, I know I'm getting old, but I usually still do a decent job of putting parts on the right storage shelf of the different make cars I work on.  Found this on the Z shelf, which I took apart 3+ years ago, and I'm not sure if it goes on the Z or not. Looks like an interior part or something.   If so, please give me a hint so I can return it to it's original location.  If not, never mind....
Thanks!   Ken
https://www.classiczcars.com/topic/64441-mystery-part/
1 hour ago, sfm6s524 said:
Obviously not from a Z, probably my kid  messin' with my head.?
It appears to not have any bolt holes for attaching it to a Z or any other car for that matter. I think your kid is messin' with you too. :rolleyes:
https://www.classiczcars.com/topic/64441-mystery-part/#findComment-605737
  • 1 month later...
Okay, back to this mystery part. I think it’s the fitting that holds the hot end of the 2” pre heater flex hose that connects to the bottom of the air cleaner cover. You know, the one most people remove because it’s such a PITA. [emoji846]. So, it slides around the front part of the exhaust manifold, and the bottom end of the flex hose connects to it. Must not be a factory part though, maybe a quick fix back in the California smog days? Anyway, don’t see any other place on the exhaust manifold or shield to connect hose, and I don’t need it where I live anyway.
https://www.classiczcars.com/topic/64441-mystery-part/#findComment-608971
  • 3 years later...
Hi all, I took apart my 1971 240Z 3 years ago, and even though I took lots of photos and documented almost everything,  I can't figure out where this felt pad was glued onto.  It's cross stitched so it's something special...anybody recognize it?20240821_112156.jpg20240821_112148.jpg
https://www.classiczcars.com/topic/64441-mystery-part/#findComment-668483
