I pull the transmission out of an engine which is been sitting for 25 years and i found at the bottom a hole in the bell housing surrounded by white powder, my best opinion is that the aluminum rot and is just disintegrating. Im cleaning as much of the transmission as i can but i dont really know of any good product to use so i going a little slow.
Is the hole is going to have any negative impact?
How can i fix it as to prevent the spread and maybe cover it?
Edited by User0945
https://www.classiczcars.com/topic/64475-bell-housing-hole/
5 hours ago, Mark Maras said:
I'd use it if I couldn't find a replacement. One could also TIG weld the damage. I seem to remember Cliff @siteunseen using cheap oven cleaner on a trans, at one time, and reporting it worked very well.
I bought the oven cleaner and is like magic, as for the weld f its not going to affect anything i might just clean it and leave it.
Thanks, im new to the transmission stuff and this might go out of the original question but i don't want to create a new post, how do i check the gears?. I know i have to rotate the input shaft but, how do i get them to change when the transmission is like that?
  • Who's Online   2 Members, 0 Anonymous, 1,512 Guests (See full list)
