Cooper260z Posted October 19, 2020 Author Share #13 Posted October 19, 2020 When I pull the choke lever, the throttle plate moves a little bit and it moves the linkage that goes to the nozzle but the nozzle doesn’t move. I can’t pull the nozzle out by hand either like I can with the other carb Link to comment https://www.classiczcars.com/topic/64580-is-one-carb-missing-a-linkage/?page=2#findComment-608442 Share on other sites More sharing options...
Captain Obvious Posted October 19, 2020 Share #14 Posted October 19, 2020 It sounds like either someone put the linkage together wrong on that carb and it's binding up, or your nozzle is just stuck frozen in place. If you take out that little screw (the really chewed up one) out of the bottom of the nozzle and completely separate the nozzle from the linkage... Can you pull the nozzle out then, or is it still stuck? Link to comment https://www.classiczcars.com/topic/64580-is-one-carb-missing-a-linkage/?page=2#findComment-608443 Share on other sites More sharing options...
Cooper260z Posted October 19, 2020 Author Share #15 Posted October 19, 2020 The nozzle is still stuck after disconnecting the linkage. Something els I noticed is that I can twist the nozzle and the thumb screw (adjuster?) and the hex closest to the carb body will all twist. On the carb with the nozzle that moves, only the nozzle will twist, the thumb screw and hex stay where they are. If that makes any sense at all... Link to comment https://www.classiczcars.com/topic/64580-is-one-carb-missing-a-linkage/?page=2#findComment-608444 Share on other sites More sharing options...
7tooZ Posted October 19, 2020 Share #16 Posted October 19, 2020 (edited) Here is an explanation of what that bar does from Ztherapy. B2CD5276-7099-4A71-8D26-05C49E52ED1F.MOV here is a view of it working. Might help Edited October 19, 2020 by 7tooZ Link to comment https://www.classiczcars.com/topic/64580-is-one-carb-missing-a-linkage/?page=2#findComment-608445 Share on other sites More sharing options...
Cooper260z Posted October 19, 2020 Author Share #17 Posted October 19, 2020 11 minutes ago, 7tooZ said: Here is an explanation of what that bar does from Ztherapy. B2CD5276-7099-4A71-8D26-05C49E52ED1F.MOV 27.63 MB · 0 downloads here is a view of it working. Might help How intuitive! I’m sure that system has never failed anyone... Link to comment https://www.classiczcars.com/topic/64580-is-one-carb-missing-a-linkage/?page=2#findComment-608446 Share on other sites More sharing options...
Captain Obvious Posted October 19, 2020 Share #18 Posted October 19, 2020 11 hours ago, Cooper260z said: The nozzle is still stuck after disconnecting the linkage. Something els I noticed is that I can twist the nozzle and the thumb screw (adjuster?) and the hex closest to the carb body will all twist. On the carb with the nozzle that moves, only the nozzle will twist, the thumb screw and hex stay where they are. Yeah, there's something wrong with that whole nozzle assembly. With that little screw out, the nozzle should slip freely in and out inside the alignment nut. The get corroded and stuck sometimes, or maybe the whole thing is so badly misaligned that it's jammed up against the needle inside the carb. That bottom assembly should not spin. There's something wrong down there. So what's the history of these carbs? It sounds like someone who really didn't know what they were doing had them in pieces and didn't do a good job of putting them back together. (Sorry if that was you.....) Link to comment https://www.classiczcars.com/topic/64580-is-one-carb-missing-a-linkage/?page=2#findComment-608465 Share on other sites More sharing options...
Captain Obvious Posted October 19, 2020 Share #19 Posted October 19, 2020 10 hours ago, Cooper260z said: How intuitive! I’m sure that system has never failed anyone... LOL. Yeah, never. Just because the adjustment method involves bending pieces of the linkage, you think it's crude or something? Link to comment https://www.classiczcars.com/topic/64580-is-one-carb-missing-a-linkage/?page=2#findComment-608466 Share on other sites More sharing options...
Cooper260z Posted October 19, 2020 Author Share #20 Posted October 19, 2020 I got these carbs from a guy that said they ran great, and in fact said that he had a mechanic friend that used to work on his Z that really knew what he was doing... guess I’ll just play with them and see what I can get to happen before I either get different ones and have them rebuilt Link to comment https://www.classiczcars.com/topic/64580-is-one-carb-missing-a-linkage/?page=2#findComment-608469 Share on other sites More sharing options...
7tooZ Posted October 19, 2020 Share #21 Posted October 19, 2020 (edited) 12 hours ago, Cooper260z said: How intuitive! I’m sure that system has never failed anyone... Well no problem. If you have a better idea of what to do go for it. I was just trying help. Those are 20 year old carbs that worked perfectly until I blew out a seal. So I had new seals and bearings put in by the company that sold them to me 20 yrs ago. Came back beautiful and started right up on the first try. All Good here. Edited October 19, 2020 by 7tooZ Link to comment https://www.classiczcars.com/topic/64580-is-one-carb-missing-a-linkage/?page=2#findComment-608474 Share on other sites More sharing options...
Cooper260z Posted October 19, 2020 Author Share #22 Posted October 19, 2020 It just seems like the bar could break if they took too much bending back and forth to tube. But if it works, it works. I was able to get the nozzle free after taking it apart and playing with it for a bit. It was just gummed up and stuck. Im still missing one of those bars that pops the butterfly open but I think I’ll still install the carbs and see how they work. I’m hoping starting and warming the engine won’t be too hard only missing a one piece of the choke system as long as I help it a bit with the pedal Link to comment https://www.classiczcars.com/topic/64580-is-one-carb-missing-a-linkage/?page=2#findComment-608480 Share on other sites More sharing options...
siteunseen Posted October 19, 2020 Share #23 Posted October 19, 2020 5 hours ago, Captain Obvious said: LOL. Yeah, never. Just because the adjustment method involves bending pieces of the linkage, you think it's crude or something? Here's crude! Why in the hell would someone need to do this? Link to comment https://www.classiczcars.com/topic/64580-is-one-carb-missing-a-linkage/?page=2#findComment-608502 Share on other sites More sharing options...
Cooper260z Posted October 19, 2020 Author Share #24 Posted October 19, 2020 Yeah, looks like someone got a bit aggressive with some of these screws. Not sure what that was about Link to comment https://www.classiczcars.com/topic/64580-is-one-carb-missing-a-linkage/?page=2#findComment-608505 Share on other sites More sharing options...
