Hello,
I have some questions on porting the e88 head from my 240z.
To give you some context I live in Germany so buying a cylinder head that flows better wont be an option and I wont hand this work over to a Professional 😄
This will be my first time porting a car head but I have ported 2 stroke cylinders countless times.
My first question is: do I really need to remove the valves to port the runners or is it ok if I clean everything exceptionally well after the fact?
I am also wondering what/how much meterial to remove (besides the port matching).
The car is prabably getting a hotter cam a bit more compression and eventually triple 45mm weber carbs
Thanks in advance and greetings from Germany.
Elias
https://www.classiczcars.com/topic/64681-diy-porting-a-240z/
I can't add much more than what has been posted already. :victorious:
The book by Honsowetz is worth every penny.
https://www.amazon.com/Modify-Your-Nissan-Datsun-Engine-ebook/dp/B0092WMDCK
Then an older thread I found about turbulence in the intakes but that's also in the book.
  • Who's Online   2 Members, 0 Anonymous, 1,512 Guests (See full list)
