HELP!! 72 240Z + 280ZX CR TRANSMISSION + 88VLSD DIF = DRIVE SHAFT?
I already rebuild the cv axles, with the new shorter shafts from WHP and got the mustache bar from Arizona Z Car. I know it's a challenge, but one that I'm intended on taking on to make it work. I'm trying to build my Z with has much datsun oem parts to keep it with in the Nissan family. I may sound a bit nostalgic, but I can't se my self doing it with other brand car parts.
1 minute ago, Zed Head said:
You'll probably need the 71B transmission mount also, I think that the T5 mount is different.  Depends on how the PO shoehorned that T5 in.
How they did it; may be why it sits too high
  • 6 months later...
6 hours ago, arcdef said:
resurrecting this one, when changing the pinion flange will it not mess up the pinion pre-load or if its torqued back to spec will it be ok?
The preload will need to be checked, and if not to spec, adjusted per the service manual.
  • Who's Online   1 Member, 0 Anonymous, 767 Guests (See full list)
