SteveJ Posted December 3, 2020 Share #25 Posted December 3, 2020 26 minutes ago, texasz said: Do you happen to have a source for these (a link would be awesome!)? https://www.google.com/search?q=rubber+isolators&sxsrf=ALeKk02RUHJ1WA2cTDb9lKNijzCXKkclDQ:1607004680379&source=lnms&tbm=shop&sa=X&ved=2ahUKEwih-oD5_rHtAhXst1kKHdQdDigQ_AUoAXoECB4QAw&biw=1920&bih=937 1 1 Link to comment https://www.classiczcars.com/topic/64782-electric-fuel-pumps/?page=3#findComment-611716 Share on other sites More sharing options...
Zed Head Posted December 3, 2020 Share #26 Posted December 3, 2020 Some BMW's, before intake pumps became the thing,, have the fuel pump mounted in a rubber container. The rubber container/bottle thing is the part that get bolted to the car. I'll post a picture if I find one. 80's cars seems like the range, if I remember. The container is about the size of an aftermarket Airtex EFI pump. Link to comment https://www.classiczcars.com/topic/64782-electric-fuel-pumps/?page=3#findComment-611721 Share on other sites More sharing options...
Zed Head Posted December 3, 2020 Share #27 Posted December 3, 2020 Also found this when I was on the Google looking for it. Looks like a Porsche part. https://www.summitracing.com/parts/uro-94461011500?seid=srese1&gclid=Cj0KCQiAtqL-BRC0ARIsAF4K3WGn2JbMHtgZeIxJ2mDW_1SMobTVCpFkRXxAYkDysbUBzwn9rJhaY_0aAlEtEALw_wcB Link to comment https://www.classiczcars.com/topic/64782-electric-fuel-pumps/?page=3#findComment-611722 Share on other sites More sharing options...
SteveJ Posted December 3, 2020 Share #28 Posted December 3, 2020 1 hour ago, Zed Head said: Also found this when I was on the Google looking for it. Looks like a Porsche part. https://www.summitracing.com/parts/uro-94461011500?seid=srese1&gclid=Cj0KCQiAtqL-BRC0ARIsAF4K3WGn2JbMHtgZeIxJ2mDW_1SMobTVCpFkRXxAYkDysbUBzwn9rJhaY_0aAlEtEALw_wcB In the spirit of Zed's search: https://www.google.com/search?biw=1920&bih=937&tbm=shop&sxsrf=ALeKk03rnIbYG8K-MBMQhxcYtL6su6WCDA%3A1607019258459&ei=-irJX-DJG4rasQXUmY_YBw&q=fuel+pump+isolators&oq=fuel+pump+isolators&gs_lcp=Cgtwcm9kdWN0cy1jYxADMgQIABAYMggIABAIEB4QGFDSDFjSDGCEGGgAcAB4AIABa4gBzwGSAQMwLjKYAQCgAQGqAQ9wcm9kdWN0cy1jYy13aXrAAQE&sclient=products-cc&ved=0ahUKEwjgrrCgtbLtAhUKbawKHdTMA3sQ4dUDCAw&uact=5 Link to comment https://www.classiczcars.com/topic/64782-electric-fuel-pumps/?page=3#findComment-611725 Share on other sites More sharing options...
texasz Posted December 3, 2020 Share #29 Posted December 3, 2020 6 hours ago, SteveJ said: https://www.google.com/search?q=rubber+isolators&sxsrf=ALeKk02RUHJ1WA2cTDb9lKNijzCXKkclDQ:1607004680379&source=lnms&tbm=shop&sa=X&ved=2ahUKEwih-oD5_rHtAhXst1kKHdQdDigQ_AUoAXoECB4QAw&biw=1920&bih=937 Ah perfect, thank you @SteveJ, I was not sure what to call them when searching...seems quite obvious now. Link to comment https://www.classiczcars.com/topic/64782-electric-fuel-pumps/?page=3#findComment-611733 Share on other sites More sharing options...
kully 560 Posted December 3, 2020 Share #30 Posted December 3, 2020 I am using a carter pump do not remember the model #. but is in the post by me as I installed it last year. I can tell you it is as quiet as a mouse. the most pressure I can get out of it is 3.47 lbs with a pressure regulator and the 3.47lbs is more than enough for the su carbs. Link to comment https://www.classiczcars.com/topic/64782-electric-fuel-pumps/?page=3#findComment-611749 Share on other sites More sharing options...
kully 560 Posted December 3, 2020 Share #31 Posted December 3, 2020 just check the posts it is a carter p60430 Link to comment https://www.classiczcars.com/topic/64782-electric-fuel-pumps/?page=3#findComment-611750 Share on other sites More sharing options...
GGRIII Posted December 3, 2020 Share #32 Posted December 3, 2020 57 minutes ago, kully 560 said: just check the posts it is a carter p60430 Thanks for that info, that pump was on my list to try. I'm sure Capt. O will wait to hear it on my car :) 1 1 Link to comment https://www.classiczcars.com/topic/64782-electric-fuel-pumps/?page=3#findComment-611759 Share on other sites More sharing options...
Captain Obvious Posted December 4, 2020 Share #33 Posted December 4, 2020 LOL. Actually I'm going to wait to NOT hear it on your car. Duh. 1 Link to comment https://www.classiczcars.com/topic/64782-electric-fuel-pumps/?page=3#findComment-611778 Share on other sites More sharing options...
Racer X Posted December 21, 2020 Share #34 Posted December 21, 2020 (edited) I shot some pictures of the fuel delivery setup on my race Z with the stoopit phone the other day. The rules require a flame retardant bulkhead between the fuel cell and the passenger compartment, so I built one with aluminum sheet picked up at Boeing Surplus in Kent, Washington (now closed and only available online - I used to go there a couple times a year, and bought lots of materials and abrasive supplies there). It also makes a great place for the dash plaques from the races I have competed in. The supply lines start in the rear corners of the fuel cell, there is a sump about 4” square to ensure an ample supply of fuel under acceleration and cornering. Passing through the access plate the lines then go through 10 micron screens, the Carter fuel pumps, check valves, then are joined up, passed through the floor bulkhead and connected to the steel tubing going to the engine bay. There a short flex line connects to a red Holley fuel pressure regulator with a gauge. The regulator has two outlets, so I ran one to each carb. The engine is prepped to ICSCC Production Car rules. Cylinder head to to manifold port matching, and necessary blending is allowed. Although never on a dyno, the guy that ported and flowed the head, manifolds and carbs estimated a theoretical 230 horsepower. Notice I mentioned the entire intake and exhaust path was on a flow bench. We realized huge gains with some creative work, including altering the length of the intake runners by using two isolators between the carbs and manifolds (gasket type and thickness is free by the rules). More important was with the the increase in airflow over a “stock” setup, with my “stock” setup, along with the increased demand for fuel. This dual pump and pickup configuration supplied fuel adequately for the rigors of racing, so it would certainly be a decent setup for a street driven Z, especially one that has been breathed on a bit. Edited December 21, 2020 by Racer X 1 Link to comment https://www.classiczcars.com/topic/64782-electric-fuel-pumps/?page=3#findComment-612982 Share on other sites More sharing options...
siteunseen Posted December 21, 2020 Share #35 Posted December 21, 2020 (edited) Double stack carb spacers? Never heard that but I'm no racer. 2 x these with longer bolts will add power? With a mechanical pump or would you need the electric like you have? I'm thinking of switching to SUs on my EFI '77 2.8 that's been "breathed" on a little bit. Opened up the ports to a trumpet looking match. It's either play with what I have or get another motorcycle, my Mom's still alive but another bike and she would drop dead. " I'm coming Elizabeth!! the dummy bought another motorcycle". I'd have to go electric for my N42 head. I have a high lift cam kit sitting on a shelf, MSA calls it a stage 3. I think it's a schneider 274? Yep, .480. http://schneidercams.com/274FL6.aspx Edited December 21, 2020 by siteunseen 1 Link to comment https://www.classiczcars.com/topic/64782-electric-fuel-pumps/?page=3#findComment-612983 Share on other sites More sharing options...
kully 560 Posted December 21, 2020 Share #36 Posted December 21, 2020 ray who use to worked at msa years ago told me about the double stacked spaces for more power , but I never did try that out . Link to comment https://www.classiczcars.com/topic/64782-electric-fuel-pumps/?page=3#findComment-613002 Share on other sites More sharing options...
