5 hours ago, z8987 said:
Sacramento Ca, where are you?
Arlington, Washington. Shipping would add significantly to the cost.
Too bad you aren’t closer, I could help you out.
Dave Rebello is in Antioch, not far from you. Give him a call.
Just make sure they detail the valve springs. ( you can tell him I said that too, as it was one of his engines that I mentioned earlier)
Edited by Racer X
Number for Dave Rebello?
1 hour ago, z8987 said:
Found it. He’s close to me. That’s exciting. Looks like he knows a thing or two about Z’s
I sent him an E31 head some years back to mill, put larger valves and seats in, port and flow. My only complaint was the coolant passages were full of chips from the machine work, and they didn’t detail the valve springs. I called to try and address it and the response was I could ship it back at my expense, and he would take a look at it.
I just disassembled it, cleaned it out and detailed the springs myself.
Edited by Racer X
That’s too bad. I just got off the phone with him. Sounds like a great guy
He has a great reputation, and has built lots of championship winning engines.
The head he did for me has been on two bottom ends I've built, I won a regional championship in 1997 with it, and it is sitting on my bench waiting for another engine to get paired up with.
  • Who's Online   0 Members, 0 Anonymous, 1,427 Guests (See full list)
