Little more playing with paint.
Air box is good enough, it ended up a little “flat” looking. It think the temp and humidity was a bit too extreme. Need to compare it side by side with the top to see if I’m happy.
ZX and ZXT alternator tensioner
Played with cleaning up some parts for platting
Decided to try and see what I could do to this wiper motor piece. It’s been stripped but seems to have another layer of platting or something that rust had eaten into.
I had already started to sand the lower right side with 120.
Not to shabby!
  • 5 weeks later...
I’ve got most things removed from the engine bay. Decided remove the battery mount so I can “clean” up underneath it. Just to hard to properly work on without removing it. It’s the only really rusty area in the bay. The other side has some surface rust from spilled brake fluid but is not as ugly.
It looks pretty rough but all the metal seems to be solid. No holes other than what I created with my first attempt at drilling out the spot welds. Couldn’t find a decent bit. Bottom holes freed up easier with a good bit.
It is easier to use a spot-weld cutter than a drill. And the cutter doesn't leave a hole in both pieces, only the part on top. This makes welding the part back on easier.
63657_I.jpg?01AD=3yh3AGrWEljXdMZyJetb6Fw
  • Agree 3
  • 3 weeks later...
Slow progress on platting prep but I’ll get there eventually.
Some hose clamps in progress
After some time in a vinegar bath and some brushing. Did find some small holes I the bracket and in the fender. Forgot to take a finished pics but just stripped it and put a light coat of cheap paint on to keep it till epoxy starts.
One done
  • 1 month later...
  • Who's Online   1 Member, 0 Anonymous, 1,444 Guests (See full list)
