Jah240 Posted February 12, 2021 Share #1 Posted February 12, 2021 Hey, I’ve searched all over this forum and can’t seem to find out how to remove the taillight black panel, I have a 72’ 240z and the forums I find include some black rivets, in my case I have some metal rivets and I don’t know how to remove them, could someone help me? Link to comment https://www.classiczcars.com/topic/65059-240-taillight-panel/ Share on other sites More sharing options...
heyitsrama Posted February 12, 2021 Share #2 Posted February 12, 2021 pictures are helpful in this case. I started off by removing the light for the plates, for the rivets (unless the metal ones are the crimped style (non oem?) ones that you have to drill out) you can push in the center to compress the splines that expand to hold the panel in place. IIRC the 240z uses a different size plastic rivet for this part of the car, its not the same as the interior ones. Link to comment https://www.classiczcars.com/topic/65059-240-taillight-panel/#findComment-615983 Share on other sites More sharing options...
Diseazd Posted February 12, 2021 Share #3 Posted February 12, 2021 Good job heyitsrama.....exactly! 1 Link to comment https://www.classiczcars.com/topic/65059-240-taillight-panel/#findComment-615988 Share on other sites More sharing options...
siteunseen Posted February 12, 2021 Share #4 Posted February 12, 2021 (edited) There's 2 small ones behind the tag too. Found the thread I was thinking about. I posted the Nissan #s in post #3. On the bottom there are clips the panel slides into. Edited February 12, 2021 by siteunseen Link to comment https://www.classiczcars.com/topic/65059-240-taillight-panel/#findComment-615999 Share on other sites More sharing options...
Clay C Posted February 12, 2021 Share #5 Posted February 12, 2021 Careful not to break the metal Clips or you will be out $120 for a set of 4 of them! 1 Link to comment https://www.classiczcars.com/topic/65059-240-taillight-panel/#findComment-616000 Share on other sites More sharing options...
jfa.series1 Posted February 12, 2021 Share #6 Posted February 12, 2021 Here is the P/N for the small rivets to secure the rear finisher, still available from your local Nissan dealer or CourtesyParts.com: 79909-E4100 Not cheap at $1.86 each (Courtesy Parts dept. pickup) but its the correct item if that is important to you. Interesting that the online parts catalog specifies qty. 8 when only 6 are required. The center panel of the finisher set uses two small hex-head bolts behind the license plate. Link to comment https://www.classiczcars.com/topic/65059-240-taillight-panel/#findComment-616001 Share on other sites More sharing options...
AZ-240z Posted February 12, 2021 Share #7 Posted February 12, 2021 1 hour ago, jfa.series1 said: Here is the P/N for the small rivets to secure the rear finisher, still available from your local Nissan dealer or CourtesyParts.com: 79909-E4100 Not cheap at $1.86 each (Courtesy Parts dept. pickup) but its the correct item if that is important to you. Interesting that the online parts catalog specifies qty. 8 when only 6 are required. The center panel of the finisher set uses two small hex-head bolts behind the license plate. Jim, are you sure that the center panel uses “hex-head bolts” behind the license plate.? I’ve alway used the same plastic rivets used to secure all of the finisher panels, for a total of eight. Dan 1 Link to comment https://www.classiczcars.com/topic/65059-240-taillight-panel/#findComment-616007 Share on other sites More sharing options...
siteunseen Posted February 12, 2021 Share #8 Posted February 12, 2021 1 minute ago, AZ-240z said: Jim, are you sure that the center panel uses “hex-head bolts” behind the license plate.? I’ve alway used the same plastic rivets used to secure all of the finisher panels, for a total of eight. Dan I was just looking at that. It seems the early 240s may have used small bolts but my '72 has two smaller plastic rivets behind the tag and the normal sized ones on the hatch lip up top, not sure how many without walking downstairs and taking the cover off. This is @CanTechZ early car. you can see the threads I think. These are the rivets i bought for my '72. Link to comment https://www.classiczcars.com/topic/65059-240-taillight-panel/#findComment-616008 Share on other sites More sharing options...
Jah240 Posted February 12, 2021 Author Share #9 Posted February 12, 2021 Well thank you all for the speedy responses, but none of you have described what I have installed currently, which leads me to believe whoever had the car behind me just inserted some random metal rivets, I shall attach pictures later on since I have the car a storage, but it’s a metal rivet that has a hole in the center of it, I’ve also tried hitting the center with a nail resulting in nothing. Thank you again I shall post pictures in a few hours Link to comment https://www.classiczcars.com/topic/65059-240-taillight-panel/#findComment-616010 Share on other sites More sharing options...
Jah240 Posted February 12, 2021 Author Share #10 Posted February 12, 2021 37 minutes ago, siteunseen said: I was just looking at that. It seems the early 240s may have used small bolts but my '72 has two smaller plastic rivets behind the tag and the normal sized ones on the hatch lip up top, not sure how many without walking downstairs and taking the cover off. This is @CanTechZ early car. you can see the threads I think. These are the rivets i bought for my '72. Where those bolts currently sit on that 240 is where the metal rivets on mine are installed. Link to comment https://www.classiczcars.com/topic/65059-240-taillight-panel/#findComment-616011 Share on other sites More sharing options...
CanTechZ Posted February 12, 2021 Share #11 Posted February 12, 2021 1 hour ago, siteunseen said: I was just looking at that. It seems the early 240s may have used small bolts but my '72 has two smaller plastic rivets behind the tag and the normal sized ones on the hatch lip up top, not sure how many without walking downstairs and taking the cover off. This is @CanTechZ early car. you can see the threads I think. My car (7/70) uses 8 of the small rivets, the last two go in the circled area below, no threads. Here are my finishers before I removed them. 1 Link to comment https://www.classiczcars.com/topic/65059-240-taillight-panel/#findComment-616020 Share on other sites More sharing options...
jfa.series1 Posted February 12, 2021 Share #12 Posted February 12, 2021 1 hour ago, AZ-240z said: Jim, are you sure that the center panel uses “hex-head bolts” behind the license plate.? I’ve alway used the same plastic rivets used to secure all of the finisher panels, for a total of eight. Dan Absolutely sure - at least on my car. It is a small flange hex-head sheet metal thread bolt, about 8mm head. These are original to my car. It is not listed in the online parts catalog, so the factory may have switched to rivets at some point, hence the spec for 8. 2 Link to comment https://www.classiczcars.com/topic/65059-240-taillight-panel/#findComment-616026 Share on other sites More sharing options...
