Posted February 20, 20214 yr comment_616425 suddenly tje clutch pedal went all over to the floor, no resistance whatsoever and cannot engage first gear. Should i change the slave and master cylinder? Which brand should i purchase? Its really weird as it was working before . Also noticed that the brake booter reservoir is half empty. Edited February 20, 20214 yr by jalexquijano Link to comment https://www.classiczcars.com/forums/topic/65086-clutch-pedal-goes-to-the-floor-with-no-resistance-canmot-engage-1st-gear/ Share on other sites More sharing options...
February 20, 20214 yr comment_616426 Hi, I would do a little more research before buying any parts. Is it just first gear or all gears will not engage? If it suddenly failed, you should be able to find a cause easily. To work one moment and then not work sounds mechanical. Hydraulic issues generally give warnings signs like spongy pedal or hard to engage 1st and reverse. It could be something other than the master or slave cylinder. Are all the linkages in place. Is the slace cylinder still bolted in position and pushrod attached? Do you still have fluid in the small clutch reservoir next the the brake booster? Hydraulic fluid leaking on the floor? Broken hose to the slave cylinder? Can you have someone work the clutch pedal while you chack the slave cylinder is working? This could mean you have a problem inside the bellhousing. Something like a broken clutch fork. I also had a clutch disc fall apart and get lodged in the pressure plate. It was instant and I could not engage any gear. The slave cylinder pushrod should move at least 20mm when you push the pedal tothe floor. Can you check if it does that? You could buy the master and slave cylinders and find the problem is something else. Link to comment https://www.classiczcars.com/forums/topic/65086-clutch-pedal-goes-to-the-floor-with-no-resistance-canmot-engage-1st-gear/#findComment-616426 Share on other sites More sharing options...
February 20, 20214 yr comment_616434 Â Pull the rubber boots from the ends of the cylinders. If there's brake fluid inside the rubber boots, the cylinder is leaking. In the past I've found that if I only replaced the one leaking cylinder (slave or master), the other cylinder didn't last long and had to be replaced or repaired. Now I replace them both at the same time. Link to comment https://www.classiczcars.com/forums/topic/65086-clutch-pedal-goes-to-the-floor-with-no-resistance-canmot-engage-1st-gear/#findComment-616434 Share on other sites More sharing options...
February 22, 20214 yr Author comment_616505 Master clutch cylinder went south. This part was never changed  Since i bought this car in 2014. Would you recommend buying beck/arnley at rockauto or any better supplier / brand? Link to comment https://www.classiczcars.com/forums/topic/65086-clutch-pedal-goes-to-the-floor-with-no-resistance-canmot-engage-1st-gear/#findComment-616505 Share on other sites More sharing options...
February 22, 20214 yr comment_616510  Beck-Arnley had a good reputation for quality in the past. I'm going to assume their quality is still good. I'd go for it, but I'd disassemble both cylinders and clean the bores. Be sure to tell us if you find any swarf in them. Have you changed the valve seals yet? Link to comment https://www.classiczcars.com/forums/topic/65086-clutch-pedal-goes-to-the-floor-with-no-resistance-canmot-engage-1st-gear/#findComment-616510 Share on other sites More sharing options...
February 22, 20214 yr Author comment_616513 Would you purchase any kit that comes with the hose, master and slave cluth cylinder? Link to comment https://www.classiczcars.com/forums/topic/65086-clutch-pedal-goes-to-the-floor-with-no-resistance-canmot-engage-1st-gear/#findComment-616513 Share on other sites More sharing options...
February 22, 20214 yr Author comment_616514 Not yet into the valve seals. Clutch first. Link to comment https://www.classiczcars.com/forums/topic/65086-clutch-pedal-goes-to-the-floor-with-no-resistance-canmot-engage-1st-gear/#findComment-616514 Share on other sites More sharing options...
February 22, 20214 yr comment_616525 5 hours ago, jalexquijano said: Would you purchase any kit that comes with the hose, master and slave cluth cylinder?  Does Beck-Arnley offer that kit? Link to comment https://www.classiczcars.com/forums/topic/65086-clutch-pedal-goes-to-the-floor-with-no-resistance-canmot-engage-1st-gear/#findComment-616525 Share on other sites More sharing options...
February 23, 20214 yr Author comment_616542 Tried looking for NABCO made in Japan and its quite difficult. Should i also replace the hose? Link to comment https://www.classiczcars.com/forums/topic/65086-clutch-pedal-goes-to-the-floor-with-no-resistance-canmot-engage-1st-gear/#findComment-616542 Share on other sites More sharing options...
February 23, 20214 yr comment_616543 Replacing the hose would be a good idea. If you don't you'll think about it for years. Link to comment https://www.classiczcars.com/forums/topic/65086-clutch-pedal-goes-to-the-floor-with-no-resistance-canmot-engage-1st-gear/#findComment-616543 Share on other sites More sharing options...
February 23, 20214 yr Author comment_616548 2 hours ago, Mark Maras said: Replacing the hose would be a good idea. If you don't you'll think about it for years. This one is available here in Panama. Dont know about the quality. Link to comment https://www.classiczcars.com/forums/topic/65086-clutch-pedal-goes-to-the-floor-with-no-resistance-canmot-engage-1st-gear/#findComment-616548 Share on other sites More sharing options...
February 23, 20214 yr comment_616552 Â I looked at a few reviews on Eagle clutch cylinders. Some report failure in a short time. I believe we've heard about this problem across many brands usually caused by insufficient cleaning of the bore before assembly. If cost isn't part of the decision process, I'd go with the Beck-Arnley and I'd disassemble that one too. Link to comment https://www.classiczcars.com/forums/topic/65086-clutch-pedal-goes-to-the-floor-with-no-resistance-canmot-engage-1st-gear/#findComment-616552 Share on other sites More sharing options...
