AZDatsun Posted March 21, 2021 Share #109 Posted March 21, 2021 It’s actually called grape jelly pearl from kirker paints painted it myself. Depending on the light it’s very purple to blue to almost black. Sorry to derail back to regular conversation Here is another angle Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/topic/65119-tuning-with-an-airfuel-gauge/?page=10#findComment-618238 Share on other sites More sharing options...
chaseincats Posted March 21, 2021 Author Share #110 Posted March 21, 2021 2 hours ago, Captain Obvious said: Well from the A/F test results you had from before, I don't think you bent it too far. You'll know for sure when you get out onto the highway again and get some new numbers. If it's too far, you'll start to run lean at the high end of cruise before the switch closes and adds the WOT enrichment fuel. I am a little concerned about the not holding position though... Do you think you fatigued the metal in the bend area? It seems to be holding the position I bent it at originally but in terms of bending it back up so WOT comes on earlier it doesn't seem to want to stay in that position... Link to comment https://www.classiczcars.com/topic/65119-tuning-with-an-airfuel-gauge/?page=10#findComment-618241 Share on other sites More sharing options...
Captain Obvious Posted March 22, 2021 Share #111 Posted March 22, 2021 Well, as long as it's holding position, lets hope it's OK. So when do you get out on the road and see if that takes care of the richness at the high end of cruise? Link to comment https://www.classiczcars.com/topic/65119-tuning-with-an-airfuel-gauge/?page=10#findComment-618254 Share on other sites More sharing options...
chaseincats Posted March 22, 2021 Author Share #112 Posted March 22, 2021 (edited) 3 hours ago, Captain Obvious said: Well, as long as it's holding position, lets hope it's OK. So when do you get out on the road and see if that takes care of the richness at the high end of cruise? And so my friends, we shut the book on this project. I drove the car about 60 miles today and settled on around 14.9-15.1's tooth for cruising and man, I'm floored at this engine. My other car is electric and I've never driven a gas powered car that runs as smoothly at speed as this does now. Adjusting the TPS was the key but I was also running it too lean earlier today, as I felt I needed to rely on the WOT pin to get any sort of power out of it. Richening the cruise out from 15.5 to 14.9ish really was the key to smell, responsiveness, smoothness and power (even before the WOT pin connects). For reference, that was richening by 1 gear tooth this also changed WOT numbers from 13.3 to 12.2. I can't thank you all enough - I hope this thread helps others in the future if they decide to tune with one of these gauges. Some other observations due to leanness I believe: - the car comes to operating temperature faster than before (but does not overheat) - the car is harder to start now if the TPS is disconnected Edited March 22, 2021 by chaseincats 3 Link to comment https://www.classiczcars.com/topic/65119-tuning-with-an-airfuel-gauge/?page=10#findComment-618266 Share on other sites More sharing options...
Captain Obvious Posted March 22, 2021 Share #113 Posted March 22, 2021 Excellent!! Glad to hear you're getting good numbers. And remember that you're getting those numbers from a completely open loop analog voodoo box that was designed 50 years ago by some genius from Germany. Seal up all the vacuum leaks, clean the electrical connections, get the fuel pressure where it belongs, tune it (as best you can with limited options) and put it on an otherwise healthy engine. Guess what... It can work! So what's the bottom line? What general numbers are you getting for idle, cruise, and WOT? And also... in the end, you moved the AFM gear about 15 teeth from where it started? That's a lot. Do you think the AFM was messed with at some point in the past thereby changing the calibration? Or do you think that other things have just shifted so much that 15 teeth was required to bring it back to where it belonged? I should have let you borrow my AFM adjustment tool: 2 Link to comment https://www.classiczcars.com/topic/65119-tuning-with-an-airfuel-gauge/?page=10#findComment-618282 Share on other sites More sharing options...
chaseincats Posted March 22, 2021 Author Share #114 Posted March 22, 2021 (edited) 3 hours ago, Captain Obvious said: Excellent!! Glad to hear you're getting good numbers. And remember that you're getting those numbers from a completely open loop analog voodoo box that was designed 50 years ago by some genius from Germany. Seal up all the vacuum leaks, clean the electrical connections, get the fuel pressure where it belongs, tune it (as best you can with limited options) and put it on an otherwise healthy engine. Guess what... It can work! So what's the bottom line? What general numbers are you getting for idle, cruise, and WOT? And also... in the end, you moved the AFM gear about 15 teeth from where it started? That's a lot. Do you think the AFM was messed with at some point in the past thereby changing the calibration? Or do you think that other things have just shifted so much that 15 teeth was required to bring it back to where it belonged? I should have let you borrow my AFM adjustment tool: Absolutely agree and here are the final numbers: Idle - 14.2 Cruise: 14.7-15.2 (depending on load) WOT: 12.3 In the end, I moved to the lean side by 2 teeth from where the PO had it set. I originally moved it 15 teeth back but that was undone once we discovered the TPS's WOT pin was to blame. Edited March 22, 2021 by chaseincats Link to comment https://www.classiczcars.com/topic/65119-tuning-with-an-airfuel-gauge/?page=10#findComment-618297 Share on other sites More sharing options...
Captain Obvious Posted March 23, 2021 Share #115 Posted March 23, 2021 Those numbers look great. I'm sure you're happy with that! I'd love to see how your engine dynos. Did you ever put your CARB system back together? Are those numbers with the system connected using the valve in the cap? Also, out of curiosity, can you see a distinct change at the upper end of cruise when the WOT switch closes and the enrichment kicks in? Link to comment https://www.classiczcars.com/topic/65119-tuning-with-an-airfuel-gauge/?page=10#findComment-618351 Share on other sites More sharing options...
chaseincats Posted March 23, 2021 Author Share #116 Posted March 23, 2021 2 hours ago, Captain Obvious said: Those numbers look great. I'm sure you're happy with that! I'd love to see how your engine dynos. Did you ever put your CARB system back together? Are those numbers with the system connected using the valve in the cap? Also, out of curiosity, can you see a distinct change at the upper end of cruise when the WOT switch closes and the enrichment kicks in? No, I completely took the carb canister out of the picture. It is still in the car/connected to the tank vent line but its vacuum hoses are disconnected. Yeah, there is indeed a change when the wot pin connects it feels kind of like when turbo boost comes in on a turbo car. 1 Link to comment https://www.classiczcars.com/topic/65119-tuning-with-an-airfuel-gauge/?page=10#findComment-618361 Share on other sites More sharing options...
Captain Obvious Posted March 23, 2021 Share #117 Posted March 23, 2021 Well (in theory) the only change you would/should see with the CARB system connected is that it should run leaner at the low end of cruise because that's where you should be pulling air through the can into the manifold. 1/4 pedal maybe? Somewhere around there. It should be a pretty tight spike as the ported vacuum that actuates the system cuts off pretty rapidly when the throttle plate isn't over the port hole. Link to comment https://www.classiczcars.com/topic/65119-tuning-with-an-airfuel-gauge/?page=10#findComment-618377 Share on other sites More sharing options...
chaseincats Posted March 23, 2021 Author Share #118 Posted March 23, 2021 (edited) 13 minutes ago, Captain Obvious said: Well (in theory) the only change you would/should see with the CARB system connected is that it should run leaner at the low end of cruise because that's where you should be pulling air through the can into the manifold. 1/4 pedal maybe? Somewhere around there. It should be a pretty tight spike as the ported vacuum that actuates the system cuts off pretty rapidly when the throttle plate isn't over the port hole. The problem is that the main carb canister chamber connected to the large vacuum hose (the one that goes directly to the manifold) does not hold vacuum so there's a permanent vacuum leak there and then a slight one via the ported chamber so I just took it out of the picture. Both chambers are supposed to be vacuum tight it seems - I tested this by spraying carb cleaner on the canister at idle and the rpms rose. I can confirm later today if the mixture changes with it plugged in though. Edited March 23, 2021 by chaseincats Link to comment https://www.classiczcars.com/topic/65119-tuning-with-an-airfuel-gauge/?page=10#findComment-618379 Share on other sites More sharing options...
chaseincats Posted March 24, 2021 Author Share #119 Posted March 24, 2021 In the post-credits scene of this thread here are my 'a couple days later' thoughts/observations: - I pulled a couple of my spark plugs just to see how they looked and they were QUITE grey indicating the car was running very lean. Now, I don't know if they got like that when we were running off the charts lean earlier and if they will return to how they looked before this or not, but the car seems to be running well and the gauge numbers check out so I guess I'll ignore them? Could my valve seats suffer if my plugs got toasted like that? - My car has a delayed start which as previously noted got worse when we unplugged the TPS but will start immediately when I jury rigged the CSV to fire on every start (https://www.classiczcars.com/forums/topic/64824-very-strange-cold-start-valve-issue/) which I'd have though was indicative of running lean. That said, I have a "Jacobs Electrical" coil/box setup (part number 380672) and the guy in the below video says if you have the wrong coil resistance (this one is correct) or if it is hooked up backwards you'll have weaker spark but the car will still run. Since the PO rewired this part of the car for the ignition box, could I flip the wires attached to the coil posts or would I risk frying the box? All the stock wire colors are of course wrong since all wiring comes from the box: Video will start at the appropriate time stamp: https://youtu.be/TlxiZXK06lI?t=647 Link to comment https://www.classiczcars.com/topic/65119-tuning-with-an-airfuel-gauge/?page=10#findComment-618487 Share on other sites More sharing options...
Captain Obvious Posted March 25, 2021 Share #120 Posted March 25, 2021 My thought is If the A/F numbers look that good, I wouldn't worry much about the plugs being light. I've heard (read on the internets) that the old method of reading plugs doesn't work so great on todays fuel using leaner ratios. Burns so clean that lighter colors often result. That toasty brown doesn't happen as much as it used to? How many miles you have on the plugs? I guess if you're thinking it might be a relic of a previous situation, you could buy new plugs and have a fresh read. As for the ignition box, I don't know anything about it. Hopefully someone else can chime in. 1 Link to comment https://www.classiczcars.com/topic/65119-tuning-with-an-airfuel-gauge/?page=10#findComment-618513 Share on other sites More sharing options...
