Some interesting parts have magically appeared in my garage over the past 2 weeks ....
This is a small sample, does anyone recognize the 2 different headers?
This is a clutch I took off a rebuilt motor I am toying with, (more on that later), am I right that it is a centerforce II?
Edited by S30Driver
Removed duplicate pix
https://www.classiczcars.com/topic/65154-name-that-manufacturer/
I concur on the clutch, looks like the typical Centerforce design with the inertia weights to increase clamping pressure as engine speed increases. I've not seen a friction disc with two different friction surfaces before though.
Can't even hazard a guess on the pipes, but other than the thin flange (I see it has blocks welded to allow for flat clamping pressure though), I like it. What size are the primaries and the outlets? Square or round ports?
  • Who's Online   0 Members, 0 Anonymous, 902 Guests (See full list)
