I was wondering if there are some alternatives to the OEM air ducting that goes from the radiator section into the body cavity. I was thinking that a 3” brake duct tube might work, it would just be a matter of figuring out some mounts for the chassis.
anyone do this before? Or have a set for sale 😐.
maybe I’ll have to listen to captain’ and start working with composites.
Edit - misunderstood the goal.
Edited by Zed Head
I’ve seen those; $200 is so expensive for that piece. 😔
i saw this online, but the mounting still has me a bit confused, it looks like a 3” duct can be used.
I should have gotten into the rock collection hobby instead.
  • Haha 2
Just realized that I got confused by the title.  "engine fresh air ducting".  Engine's got nothing to do with it, right?
If a person really studied why Nissan put all that work and parts in to creating a special path for the air to the side vents...they'd probably still end up not understanding.  If you ran a tube up the cowl air source, where the fresh air for the heating/cooling system enters, you'd have high pressure fresh air directly to the vents.  Might not even need the large diameter because it will be pressurized while driving.
https://www.amazon.com/dp/B000BPZ55Y?psc=1&smid=ATVPDKIKX0DER&ref_=chk_typ_imgToDp#customerReviews
Alright $12 bucks for 28" of 3in ducting. This was the cheapest that I could find online. Might have some extra to use on the airbox.... The mounting solution is still up in the air.
  • Who's Online   2 Members, 0 Anonymous, 1,582 Guests (See full list)
