As part of what will probably be a multi-year effort to get my 04/71 240Z back on the road, I'm cleaning up the front suspension. I've removed the struts from both sides and got a little help from a local garage to remove the springs. Since the attached picture was taken, I've removed the gland nuts and old cartridges (they were the Made in Venezuela type that I've seen mentioned in this forum). The combination of crowbar and 24" pipe wrench can be quite persuasive.
I'm going to replace the cartridges, but while I'm waiting for those, I'll clean everything up and would like to paint/coat things before re-assembling. Last summer I cleaned up the gas tank and POR-ed it inside and out (two different treatments, of course). While I was at it, I did the front stabilizer bar, which I'd already removed. Any thoughts on what type of treatment to give the strut casings, backing plates, hubs (business parts excluded) and even springs? I don't have paint spraying tools, so brush or rattle can solutions are what I'm looking at. Should I be concerned about having paint in the middle of the connection points between the struts and calipers, etc.?
One separate question. Is there a trick to separating the rotors from the hubs? I've removed the bolts, but haven't wanted to pound on anything to separate them.
https://www.classiczcars.com/topic/65224-suspension-cleanup-and-refurb/
For my suspension I used  7776 flat black rattle can, it’s held up pretty well to me running off track and getting loads of mud and dirt on the under side.
I’ve also done Por15 rust encapsulation, then a topcoat with spray cans. If you take the time you can get a fairly nice outcome.
Just make sure you go through all the steps, acetone washing, primer ( I do 2 layers) , then paint (I do 2-3 layers). The key is to have very clean prep, you always start out dirty and rusty, and clean with each step all the way to installation. But after that getting down under the car is not too bad, plus it’s shiny 🙂
do you have a 1/2” air impact gun? That will take the bolts out, might be hard to do with hand because it wants to spin.
if you don’t have an air impact imma take the time to say consider getting an electrical one from Milwaukee tools, it’s a beast of a tool, makes working on cars not too bad.
OK, great, that's the sort of coating I was thinking I would do. The entire underside of the car was sprayed with some sort of thick protective undercoating (which seems to have been effective), but it's a giant mess on the suspension components.
The bolts holding the rotors and hubs together came off nicely using a 1/2" breaker bar after many applications of WD40 Rust Penetrant. The Milwaukee air impact gun seems like it might be good to have around, though. The hub/rotor assemblies are coated in surface rust, though, and I can't tell where they're actually supposed to separate. "Gentle" coaxing hasn't pulled them apart yet and I'd like to understand where to apply pressure without doing any damage. Can I just leave the four bolts loosely screwed in and tap on those, or ...?
Pound away, the cast hub is pretty soft metal so try your best only to hit the brake disc, a couple of good wacks on either side of the disc should get it started.
Thanks guys! Hopefully at some point tomorrow morning I'll be able to announce successful separation of hubs and rotors. After that I have a lot of wire-wheeling to do. And I have to order replacement shocks. I think I'm just going to go with the KYB's. I was thinking about the "new" adjustable Koni's, but I'm never going near a track, and always found the car's ride plenty hard. I'm assuming the softest adjustment level of the Koni's is roughly the level of the KYB's. Any thoughts on that?
1 hour ago, davewormald said:
Don't know why they bother with bolts.
A bit late to the party . . . . .
For what its worth, I use a press if available to push the wheel studs out. Less risk of damage and the studs can usually be reused if otherwise in good condition. Use the press to reassemble.
If a press isn't available, you can use a square of 3/4" plywood on the shop floor, set the hub on it with an mag wheel old lug nut on the stud a 1/4" or so, and beat the stud out with a brass hammer. Use the hammer and a drift to reassemble, and the old lug nut and a few flat washers to pull them all the way in (smear a dab of grease between the washers to reduce galling).
I wasn't very clear with my comment about the bolts. It was meant to be a sarcastic remark that the rust connection between the hubs and rotors was strong enough that the bolts holding them together seemed superfluous. I used a properly Canadian solution of a hockey puck under the inside end of the hub while pounding directly on the rotors with a hammer. My original problem was that I couldn't tell where the rotors ended and the hubs started. Once I found images of what they looked like individually, I was more confident taking @grannyknot's advice.
I haven't tried to take the studs out yet, but will probably need to do that in order to clean the hubs up properly. Thanks for the suggestions on how to do that @Mark Maras and @Racer X
Back to my wire-wheeling and part cleanup ...
32 minutes ago, heyitsrama said:
@davewormald I think rock auto has a rebate on KYBs if you order the whole set.
I'll check that out. I might as well order the rears at the same time, even though I might not get to those for a while. Thanks!
I know you'll all be shocked to hear that saving money on the KYB's just cost me a small fortune in parts I wasn't there to buy ...
Edited by davewormald
  • Haha 2
  • Who's Online   2 Members, 0 Anonymous, 1,227 Guests (See full list)
