Need a big favor. My hatch has had the holes for both hatch emblems filled in. Not sure why. Before i start painting it i need to know where the holes should be. Does anyone have a diagram with measurements or can someone take a photo of theres with measurements from right side of hatch and bottom of hatch so i will have a good est. of where to put holes? much appreciated. if  matters is 1971 240z series 2
last what are small recessed things that hold in emblems. some kinda clips
Edited by Wally
https://www.classiczcars.com/topic/65238-hatch-emblems/
Video Player is loading.
Current Time 0:05
Duration 0:19
Loaded: 100.00%
Stream Type LIVE
Remaining Time 0:14
1x
Wally,
We have a '71 series 2 car coming in. It is also missing the hatch emblems. I can take pictures and messurements for you when it arrives. Will this car give you what you need? Is series 1 and series 2 different?
Ed
https://www.classiczcars.com/topic/65238-hatch-emblems/#findComment-618912
It may have had a spoiler sometime in it's life. Mine does and the holes are filled in, emblems are mounted on the spoiler.
https://www.classiczcars.com/topic/65238-hatch-emblems/#findComment-618915
I'm pretty sure they are the same for series 1 and 2, here are measurements from my 1970. The datum for measurement is the lower right corner of hatch. The bottom edge of the hatch is curved so instead of the that edge I drew a line at right angle to the right edge for the vertical dimensions. I hope that makes sense.
  • Thanks 2
https://www.classiczcars.com/topic/65238-hatch-emblems/#findComment-618917
Awesome idea!
2 hours ago, Wally said:
you guys are awesome. exactly what i was needing. thanks
Maybe @CanTechZ could mail you a copy of his template.
https://www.classiczcars.com/topic/65238-hatch-emblems/#findComment-618932
  • Who's Online   1 Member, 0 Anonymous, 1,454 Guests (See full list)
