240260280z Posted April 1, 2021 Share #1 Posted April 1, 2021 https://www.ebay.com/itm/Datsun-240Z-Triple-Weber-Carburetors-42DCOE-8-with-Intake-Manifold/265108008294?epid=1025136937&hash=item3db9ab2d66%3Ag%3AeFoAAOSw-oZgZTBW&LH_ItemCondition=4 Link to comment https://www.classiczcars.com/topic/65245-fyi-flip-these-and-make-5k/ Share on other sites More sharing options...
heyitsrama Posted April 1, 2021 Share #2 Posted April 1, 2021 What’s so special about those ones? Datsun competition? Link to comment https://www.classiczcars.com/topic/65245-fyi-flip-these-and-make-5k/#findComment-619026 Share on other sites More sharing options...
zKars Posted April 1, 2021 Share #3 Posted April 1, 2021 (edited) When you google them, they are associated and spec’ed to ridiculously expensive exotics Ferarri, Mazeratti etc. Hence their crazy value. Quite rare and quite valuable. $1800 would be a steal. Ebay has a new set at the going value, no intake etc. Edited April 1, 2021 by zKars 2 Link to comment https://www.classiczcars.com/topic/65245-fyi-flip-these-and-make-5k/#findComment-619029 Share on other sites More sharing options...
Patcon Posted April 1, 2021 Share #4 Posted April 1, 2021 The only problem with use Webers is you can really mess up the body and small ports if you crank the idle screws down... Hard to know until you try to tune them or if the screw tip shows in the throttle bore Link to comment https://www.classiczcars.com/topic/65245-fyi-flip-these-and-make-5k/#findComment-619032 Share on other sites More sharing options...
