Need machine shop that can align bore L28 cam towers
Due to excessive wear of the bores in the cam towers, I am in the process of making and inserting bronze bearing inserts.
So far, my search for a machine shop capable of align boring them has turned up one shop in Ohio, JCM Machine and Coatings.  I am in Virginia.  Though I have done it before, I am not delighted by the idea of shipping my head off somewhere.  I'd much rather see their operation, look the man in the eye, and so on.
Does anyone know of a shop that can do this work (and do it brilliantly!) - anywhere, but local would be ideal?
@madkawI decided to start a thread for this project to explain some of the work I am planning.  I will reply to your question there.
It's titled: Another Z to see the roads again...
@DerekThanks for that input.  My concern is that used towers are unknown quality/condition.  New bearings and bored to specification, assuming it is done properly eliminates any problem of a loose bore (loss of oil pressure, flexing of the cam, maybe loose engine noise which I hate).  More on the other thread.
Yeah - .0015 - .0020 interference.
The coefficients of expansion are ~12.5 for aluminum and ~9.76 for bronze.  If the towers see a temperature change of 120F (bearings made at 80F, engine warms to 200F), then the bore in the towers would increase from 2.0400 (1.8898 + bearing wall thickness of .075) to 2.0431.
The bearing OD would change from 2.0415 (2.0400 + .0015) to 2.0439, so still an interference of about 8 tenths.
I'm beginning to like @madkaw's suggestion of sourcing another head.
