I'm using new 73 style pistons and want to upgrade cam to Comp Cams 280S-110 grind. The head has been surfaced at -.012. My main concern is valve clearance, I do plan to use cam tower shims but I'm unsure how many it might take to make this combination work.
Thanks for your help.
Specs for stock v. Comp Cams:
Comp Cams
Advertised Intake Duration: 280
Advertised Exhaust Duration: 280
Intake Valve Lift: 0.460
Exhaust Valve Lift: 0.460
Stock Cam L24
Intake Duration:   248
Exhaust Duration:  248
Intake Valve Lift:  0.413
Exhaust Valve Lift:    0:413
Edited by rem1313
incorrect information
https://www.classiczcars.com/topic/65360-73-240z-engine-rebuild-questions/
