77 280z. Rear hatch side bracket has this brown, cork material. Is that oem material that has eroded since 77 or is that bushing material?
I did notice under the brown material is a screw.  Wondering if that brown cork material is OEM?  Stuffed sponge? Wine cork?  All opinions are welcome.
Edited by JggyZ
Spelling
Deleted everything I had here before because it was wrong.
Here's a pic from ebay with a pair of those in pretty good shape. I think this is what they looked like at one time. Not sure if they changed the color of the rubbery nugget over the years though.
Edited by Captain Obvious
  • Thanks 1
I am pretty sure that is correct. These and the piece on the hatch itself are both clear zinc. I see some people yellow them as well as a lot of other parts that should be clear.
4 hours ago, Terrapin Z said:
It looked like this when new. Still available from Nissan. $21.47 each
Yup them be the ones! Rear hatch post.  Recommend I replace it based on that corklike mush sitting in the pocket?  Can I just get rid of that brown stuff and keep the post as is (not rusty).
I would. At least contact 240zrubberparts and see if he can make a set for you. He lists "Out of stock" a lot, but will make things if requested.
They hold the spring in place and act as a stopper for the white plastic slide piece. The little feet on the sides hold them in and often break off. Used ones like CO's eBay set would also be a way to go.
I might even have an extra set.
I didn't even realize that part was there.  Those have totally 'perished' from my 76, and I thought the spring was retained merely by a little nib at the bottom.
Appreciate the lookover.  Let me see if I can just replace these with still manufactured OEM Rear posts.
Edited by JggyZ
  • Who's Online   1 Member, 0 Anonymous, 1,503 Guests (See full list)
