chaseincats Posted May 16, 2021 Share #1 Posted May 16, 2021 (edited) Hi guys, I noticed yesterday a periodic gasoline (not exhaust) smell in the cabin while driving with the windows down. With the windows up, the smell disappears. I opened the hood while the car was running and didn't smell any gasoline then got under the car near the fuel pump and didn't smell it there either. I thought it could be the vapor tank hoses but if that was the case, I'd smell it in the cabin all the time I'd think. I can only smell it while driving with the windows down. Any ideas? EDIT: I started it and sniffed all over the engine bay and it seems to be coming from the passenger side firewall area (near the battery). I'm guessing it's being blown back there by the fan. I tightened all the fuel line hose clamps (which I was able to tighten maybe a quarter turn) but the hoses looked fine. I checked my carbon canister's filter which looks brand new. Any other spots I should check? I really only smell it while the car is running. Edited May 16, 2021 by chaseincats additional information Link to comment https://www.classiczcars.com/topic/65392-in-cabin-fuel-smell/ Share on other sites More sharing options...
rcb280z Posted May 16, 2021 Share #2 Posted May 16, 2021 Check your fuel filter and fittings for (if you installed one) your inline fuel pressure gauge. Link to comment https://www.classiczcars.com/topic/65392-in-cabin-fuel-smell/#findComment-621691 Share on other sites More sharing options...
chaseincats Posted May 16, 2021 Author Share #3 Posted May 16, 2021 22 minutes ago, rcb280z said: Check your fuel filter and fittings for (if you installed one) your inline fuel pressure gauge. The fuel filter and lines are brand new and pretty tight on there (no pressure gauge but I may get one in the future). Link to comment https://www.classiczcars.com/topic/65392-in-cabin-fuel-smell/#findComment-621692 Share on other sites More sharing options...
ETI4K Posted May 16, 2021 Share #4 Posted May 16, 2021 (edited) Carbs or EFI? If carbs, it could one or more is venting an overflow of fuel in the carb bowl. Debris can hold the needle valve open, or may have lost a float to old age. If EFI, it'd be obvious if a fuel hose was leaking since it's at the same relatively high pressure all the time. If a hard line is cracked, perhaps it only weeps when the motor moves on accel/decel. Edited May 16, 2021 by ETI4K Link to comment https://www.classiczcars.com/topic/65392-in-cabin-fuel-smell/#findComment-621694 Share on other sites More sharing options...
grannyknot Posted May 16, 2021 Share #5 Posted May 16, 2021 Back in the 70's every car smelled like gas, it was normal. Mmmmm, leaded gas, I miss that smell. 3 Link to comment https://www.classiczcars.com/topic/65392-in-cabin-fuel-smell/#findComment-621695 Share on other sites More sharing options...
AK260 Posted May 16, 2021 Share #6 Posted May 16, 2021 OK some thoughts for you to consider:On mine I used to get this a lot. The PO bless him, had forgotten to do up the jubilee clips from the breather pipes at the rear of the car, behind the trim. When the windows are opened, we create negative pressure inside the car and it sucks though any orifice at the rear of the car. This was pulling in escaping fuel smells.Secondly, as already suggested, your passenger side has all the fuel coming into the engine bay, so if you are smelling it there, then that’s a good place to start to look for potentially damaged hoses. One Z club UK member found that his engine bay had a “mist” hovering over it. He then was horrified to discover his one year old braided fuel lines had perforated due to ethanol damage.Thirdly, sometimes the carbs can have a sticking valve in the float chambers and be leaking fuel through the overflow pipes or through the jet area or both.Make sure you carry a small fire extinguisher / blanket in the car. You’d be amazed how quickly fuel vapour can catch !!!! Link to comment https://www.classiczcars.com/topic/65392-in-cabin-fuel-smell/#findComment-621696 Share on other sites More sharing options...
chaseincats Posted May 17, 2021 Author Share #7 Posted May 17, 2021 2 hours ago, ETI4K said: Carbs or EFI? If carbs, it could one or more is venting an overflow of fuel in the carb bowl. Debris can hold the needle valve open, or may have lost a float to old age. If EFI, it'd be obvious if a fuel hose was leaking since it's at the same relatively high pressure all the time. If a hard line is cracked, perhaps it only weeps when the motor moves on accel/decel. It's EFI. I'll try to start it in the garage and look under it for wet spots on the lines. Link to comment https://www.classiczcars.com/topic/65392-in-cabin-fuel-smell/#findComment-621701 Share on other sites More sharing options...
chaseincats Posted May 17, 2021 Author Share #8 Posted May 17, 2021 2 hours ago, AK260 said: OK some thoughts for you to consider: On mine I used to get this a lot. The PO bless him, had forgotten to do up the jubilee clips from the breather pipes at the rear of the car, behind the trim. When the windows are opened, we create negative pressure inside the car and it sucks though any orifice at the rear of the car. This was pulling in escaping fuel smells. Secondly, as already suggested, your passenger side has all the fuel coming into the engine bay, so if you are smelling it there, then that’s a good place to start to look for potentially damaged hoses. One Z club UK member found that his engine bay had a “mist” hovering over it. He then was horrified to discover his one year old braided fuel lines had perforated due to ethanol damage. Thirdly, sometimes the carbs can have a sticking valve in the float chambers and be leaking fuel through the overflow pipes or through the jet area or both. Make sure you carry a small fire extinguisher / blanket in the car. You’d be amazed how quickly fuel vapour can catch !!!! Definitely - a fire extinguisher was one of the first things I bought when I got the car years ago haha 2 Link to comment https://www.classiczcars.com/topic/65392-in-cabin-fuel-smell/#findComment-621702 Share on other sites More sharing options...
chaseincats Posted July 20, 2021 Author Share #9 Posted July 20, 2021 Sorry, I did not close this thread. The issue was the clips around my new fuel filter which were tight but apparently not tight enough. Link to comment https://www.classiczcars.com/topic/65392-in-cabin-fuel-smell/#findComment-625394 Share on other sites More sharing options...
bpilati Posted July 20, 2021 Share #10 Posted July 20, 2021 This topic never goes away, after all you own a Z.🤣 1 1 1 Link to comment https://www.classiczcars.com/topic/65392-in-cabin-fuel-smell/#findComment-625410 Share on other sites More sharing options...
AK260 Posted July 20, 2021 Share #11 Posted July 20, 2021 Just been out for a blast in mine and being 27°c with 85% humidity @22:00, I had the windows down, listening to the warble of the L28. Two things happened:1. I had knocked off the rubber hatch seal and was sucking fumes - so now I feel light headed and have a head ache. Definitely worth getting it sorted, well done you! [emoji106]2. My ears are ringing like I’ve been to a rock concern!! (And I still have the quietest of all, “Street muffler” on the car!) 1 Link to comment https://www.classiczcars.com/topic/65392-in-cabin-fuel-smell/#findComment-625431 Share on other sites More sharing options...
chaseincats Posted July 21, 2021 Author Share #12 Posted July 21, 2021 4 hours ago, AK260 said: Just been out for a blast in mine and being 27°c with 85% humidity @22:00, I had the windows down, listening to the warble of the L28. Two things happened: 1. I had knocked off the rubber hatch seal and was sucking fumes - so now I feel light headed and have a head ache. Definitely worth getting it sorted, well done you! 2. My ears are ringing like I’ve been to a rock concern!! (And I still have the quietest of all, “Street muffler” on the car!) Get your cabin fan going - that will equalize the pressure and push the fumes out. 1 Link to comment https://www.classiczcars.com/topic/65392-in-cabin-fuel-smell/#findComment-625437 Share on other sites More sharing options...
