Do the fuel send and return lines go above the parking brake rod?  I am installing new lines from Classic Tube and of course now I can't remember if the lines routed above the parking brake, which would be a pain.  I could have sworn I had lines routing above, but perhaps it was brake or vapor.
https://www.classiczcars.com/topic/65408-hard-fuel-line-routing-240z/
My error. Your pic of the insulator/mount helped refresh me and I was able to locate a pic of my lines straddling the rod. The larger fuel supply line does run under the rod, the other three lines are above it. Sorry for the bad info.
Thanks for confirming!
