ok - i am just going to hook up the 280zx dizzy..  is it that easy - 2 wires ? 2 from coil to new dizzy? which wire is tach and where does it go? is that light blue on my coil - the tach?
thanks
Edited by Shawninvancouver
1 hour ago, Shawninvancouver said:
Ok just need to know what’s gauge wire to use for wires from coil to new dizzy.  and will this coil be ok.. Thanks.
Use the wiring  that is already on the car.
And yes, that coil should be fine.
CASE CLOSED - car RUNS!!!!  new   280zx dizzy fixes the problem... took out electronic ignition unit and ballast... thanks for the help..
can i now start a new thread on how to tune it up and get it to run normal???
  • Like 3
Congratulations.
I dunno, can you?
Edited by Racer X
1 hour ago, siteunseen said:
I have one of those, never used it. There isn’t enough room between the carbs and strut tower.
Someone gave me one of these:
It is easy to use and allows enough room to be quick and accurate.
Never an issue on my '72 with 2 SUs. I remove the air box completely. Took me a minute to figure out the hole on the side that allows air in. Mine was pegging out at first then I rotated it around to open up that hole and pull some outside air in. Then it was a lot easier to use.
  • Who's Online   2 Members, 0 Anonymous, 1,527 Guests (See full list)
