5 hours ago, bartsscooterservice said:
If i change the drive gear?
Why would you change the drivegear? You only have to put in the km gauge for the mls gauge (there are different drivegears but not for that, they are for if you install other diff's or tire hights.. (wheeldiameters!)
Then..
The 280zx 5 speed requires trans tunnel modification for the shifter right?
That i don't know but.. if you install the euro Fs5c71B (Like i did.)  you have to convert to the type 2 tunnel console!  and take a small piece of metal out of your tunnel otherwise the shifter will hit it..
  • Who's Online   3 Members, 0 Anonymous, 551 Guests (See full list)
