Yes, the green wire is the ground wire for the relay solenoid.  When you press the horn button the green wire is grounded, actuating the relay, which then passes power to the horns.
You can take that green wire and touch it to a ground and the horns will get power.  Honk.
1 hour ago, Shawninvancouver said:
But when I’m testing green at horn - it has power.   When I press button it still has power.  Is that. Wrong ???
That is all correct.  The power is used to actuate the relay, which then lets power through to the horns.  The horn button always has power, that's why the horn always works, key on or off.
Ok.  Got fuel and amp gauge working abs side markers.   Unplugged C3C4C5 I wiggled C3 as it’s way up there and a few things started working.  Now just horn left.  I assume I need lots of gas in tank to register like quarter tank.  I just had a Jerry can do it shows empty.  Now just horn. If horn relay is working will I hear it click or not,?
